Unread 06-30-2009, 07:18 AM   #1
Diane
Diane's Avatar
Your Ride: 2003 325ci
325CI Window switch
Good morning everyone!!
My 2003 325ci drivers window switch(the buttons) are broke.I understand that I need to purchase the complete window switch. Does anyone know any sights that will explain how to access the console to replace this switch? I've searched th internet with not much luck!!
Unread 06-30-2009, 09:44 PM   #2
Best bet would be to get a Bentley manual, or see if your library has one. You might also get some idea of what's involved, at least getting a schematic diagram, at www.realoem.com/bmw
Unread 07-03-2009, 01:40 PM   #3
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea Send a message via Skype™ to doughboyea
Try here:
UB Forum, BMW Service Manual
Let me know if it helps you out.
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1999 BMW 328i E46 Dinan Stg. 1
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Unread 10-26-2009, 11:42 PM   #4
fxoaxaca
Your Ride: 1996 328is
If it's anything like the 2002 325ci, you lift the boot around the shifter (for an automatic) and there are two screws holding the rearmost portion of the shifter surround where the switches are. Remove the screws and the whole thing lifts up and you can easily access the switches.
Power window switch replacement mtudude33 E46 1 03-16-2011 02:40 AM
Need washer pump & window switch!!! beltwaybob M3 1 01-27-2010 03:26 PM
Need washer pump & window switch !!!! beltwaybob E36 0 05-21-2009 01:38 PM
Is this the infamous window regulator problem? spicytuna E46 3 11-11-2007 01:34 AM
330ci window switch njjeter E46 2 07-21-2007 04:11 PM
