Unread 06-23-2010, 03:17 AM   #31
BrandoomE34
BrandoomE34's Avatar
Your Ride: 1992 525i
I am having similar problems with my e34. motor turns but will not start. replaces spark plugs, old ones were really bad and had oil on them and ive now found out that my fuel pump is not turning on when i turn the key.
Do you know where i might find the fuel pump relay? fuse is fine.
Unread 07-10-2010, 08:24 AM   #32
macky55e34lover
macky55e34lover's Avatar
Your Ride: BMW '94 E-34 525i
we,, if you had the battery recharged and it started, you have to check with the electrician and see if the alternator is working properly, maybe its not charging anymore, check all of the sensors also specifically the crank sensor, if this is busted, there are times that it will run then suddenly stop without warning
02 X5 remote start. not functioning correctly njboost Car Audio and Electronics 0 01-27-2008 02:48 PM
4 10-05-2005 11:37 AM
