Unread 06-03-2009, 08:56 AM   #1
chaswr7
Your Ride: 2000 M Roadster
Rear end Noise and Shifter issue
I just bought a 2000 M Roadster. I have two questions:
1. There is a click/squeak (not sure how else to describe it) coming from what sounds the like the rear driver side while driving. It stops when braking. I lifted the rear end and turned the wheel by hand. The wheel spins freely buy on each revolution there is a spot where I can feel some slight drag from something rubbing i would assume. My guess is either a warped rotor or wheel bearing. I dont feel anything in the handling under acceleration, braking, or cornering.
2. Yesterday after driving around for a bit it became pretty much impossible to put the car into gear if not moving. If i was rolling even slightly i could put it in gear but it was still difficult. While driving through town I did not have any problems. This morning when i left for work however it shifted just fine, even at a dead stop.
Any help will be much appreciated. I will try to answer any questions as best as i can.
Unread 07-24-2009, 10:57 PM   #2
Sunzout
Your Ride: '00 M Roadster
1) could be a rock or stone caught in the backing plate/rotor
2) Shiftpins - in the trans - they stick but try new fluid in the trans and bleed the clutch first as they are easy and cheap.
Vibrating Noise from Shifter handle (when backin up) Mercenary(FH) E36 28 04-21-2007 11:59 PM
