Unread 04-15-2009, 01:08 PM   #1
havensmom07
havensmom07's Avatar
Your Ride: 99 328i
so so lost.....
Ok...so I'll start with this. I have a 99 328i 98k....has been an awesome car....then on Monday it just decided to flip out on me. I started it that morning...it did some random idling....was fine when I put the car in gear. After about 2 miles it just started shaking and missing really reallllllly bad. So....I called the BMW guy....he said clean the ICV.....done.....did NOT work...he said check your head gasket....done....did NOT work....he said replace s.plugs and check coil packs....done....did NOT work....so WTF? BMW guy is at a loss himself without cracking into it and well....I do NOT have the money to let him do that right now.....
About a month ago I replaced 2 o2 sensors because codes check said it needed it.....Is is the camshaft sensor? What else can I check to figure out what my babies illness is?
Please help. I really would appreciate it!!! And plz dont be a dick to me.
Unread 04-15-2009, 02:57 PM   #2
m3m3m3
Title: Sitting in Time out
is the check engine light on? do you have a code reader? any errors?
Unread 04-15-2009, 04:15 PM   #3
havensmom07
Your Ride: 99 328i
It was on. It read bad o2 sensor. I replaced it and now its off but it is still shaking and missing.......
Mis_T
Unread 04-16-2009, 12:21 AM   #4
Kistoni
Rate My Car: 236 / 340
Your Ride: 316i '95
Send a message via Skype™ to Kistoni
If it is just on idle it could be a vacuum leak. Check for whistling noise from under the hood. Check all rubber hoses and bellows on air intake. When you were told to check the head gasket they probably meant the valve cover gasket as this is also prone to leaks. A vacuum leak could have caused the O2 sensors to fail as it would make the engine to run rich and fowl the sensors.
Good luck and let us know how you get on.
Unread 04-16-2009, 10:26 AM   #5
havensmom07
Your Ride: 99 328i
A few months ago I did have to replace a worn hose but we have checked and rechecked all the hoses. Today I'm replacing the valve cover gasket even though it doesnt seem to be the problem, I just figure I'll replace it all while I've got it apart.
Thanks!!!
Mis_T
Unread 04-20-2009, 02:56 AM   #6
Maxi
Maxi's Avatar
Your Ride: BMW E46 328i 99
Hi, any update?!!
Maximum Power
Unread 04-20-2009, 11:43 AM   #7
havensmom07
Your Ride: 99 328i
Well....parts replaced.....valve cover gasket, another o2 sensor and coils 1&6......she's back to her wonderful self again! Yay!!!!
Mis_T
Forum DOWN TIME and LOST DATA scooter United Off Topic  **FOR MEMBERS ONLY** 1 10-24-2008 05:31 AM
I got lost trying to compare all the MP3 models so.... dennis1 Geek Chat 3 07-11-2007 12:49 AM
i lost my voice Hoppy United Off Topic  **FOR MEMBERS ONLY** 10 01-07-2006 10:19 AM
Lost Topic bmw4life Site Feedback 24 12-10-2005 04:19 PM
Japan Space Robot "Minerva" Lost in Space komodo United Off Topic  **FOR MEMBERS ONLY** 1 11-15-2005 12:09 AM
