Lighting
Sponsored by: BavToys.com
Unread 03-16-2009, 02:56 AM   #1
beemeroy
Your Ride: 2001 530d
Question Only one brake light works
Hi guys, this is my first time on here, hope you can help me. I am not particularly clever at engineering or electrics but can get by if its not too dificult.
My problem is that on my 2001 530d the offside (UK) brake light does not work. I have replaced the bulb, and even swapped over the nearside and offside bulbs and holders but still the offside does not work.
Any suggestions please.
Unread 04-17-2009, 03:02 PM   #2
railhead
Your Ride: 89 325i
You might try a light tester in the light socket w/someone holding down the break pedel and see if you have power. If so check you ground for that side.
Unread 04-18-2009, 03:08 AM   #3
beemeroy
ok thanx, will give it a try
Unread 05-02-2009, 01:25 PM   #4
strawdrag
Your Ride: 1996 328is
yup i think thats the problem.
Unread 10-11-2010, 02:24 PM   #5
rich7669
Your Ride: 2000 520
I have that problem too, only I don't have the reverse light either and the bulbs work. I've seen a lot of E39s with just the one brake light working. The drivers side one. Seems to be a common problem. Please let me know what you found out beemeroy.
Unread 06-10-2011, 04:17 AM   #6
StephanFlaming
Your Ride: 2003 Ford
Motorexpress
I have the same problem with my car and found the error was in the wiring which was not properly done! Have you check your wiring ? Whether it is properly done or not.
Unread 06-12-2011, 02:25 PM   #7
rich7669
Your Ride: 2000 520
Thanx for your response. I had not checked it It has been rewired tho it seems before I bought the car. Did you get yours rewired? Was it expensive or did you do it yourself?
Rich
Brake Light Circuits cruzn4abruzn E36 6 12-08-2014 09:01 AM
Brake light circuit fault message 3050rpm E36 4 05-20-2009 01:16 PM
Brake light HyeTide E21, E30 3 11-11-2008 08:13 PM
brake sensor light on dash 215BIMMER535 E36 13 03-01-2007 05:25 AM
