Unread 03-02-2009, 09:48 AM   #1
Grahamp
Your Ride: 1998 E36 328i Auto
Question E36 328i Auto 1998 - Starter does not turn over when hot.
I own a 328i Auto, which has been a reliable car for the past 7 years, since 2001. I have bought it at about 60 000 kms and have now done about 180 000 kms. so it has given us great motoring!
Recently, it has become less and less reliable to start after parking in the sun or a long run on a hot day. Temperatures here in South Africa get up to 36 degrees C at times in summer. The cure for this is to open all windows and turn on the blower for about 5 minutes and then to try to start again. Most times it works and starts instantly, however it is temperamental especially after shopping at the mall on a hot day.
Using the generic E36 Haynes manual, I think it could be the starter interlock relay, however the relays under the hood and inside the car (left and right), just don't correspond to the diagrams.
1. Where is the starter relay ? I will start by replacing it.
2. Failing that, I might replace the ignition switch, on the assumption that it could be worn after this mileage.
Has anyone experienced this particular fault on the 328i Auto or Auto E 36 models before ? Can you throw some light on the problem ?
Unread 07-01-2009, 05:46 AM   #2
tauki
Your Ride: 1997 bmw 323 (m52)
after market anti theft dervise
hello.I' ve read about u problem.do u stil have the same problem.If not what did u do,becouse it seems as if I have the same problem.do u have these after market anti theft dervise
Unread 07-01-2009, 05:25 PM   #3
Normally the relay you're looking for is located in the fuse box under the hood of the car. That would be the battery junction box, in the car under the dash is the central junction box, and I'm not sure how yours is equipped but there is sometimes a body control fuse box under the back seat (although I think that's more of a 5 series thing). You may want to try cleaning the cables and connections to the starter (replacing the relay is cheap and easy so why not?) and get your battery/battery cables checked, make sure they're clean and tight. If all that fails it may be time for a starter or ignition switch. How heavy is your key chain?
E36 328i will not start PaulY1972 E36 7 06-10-2011 02:15 AM
1998 BMW Z3 1.9L Auto ggabriel Z Series (Z3, Z4, Z8) 3 10-27-2008 12:12 PM
FS: 1998 BMW 328i MUST READ ///Menace328i Bmw Cars For Sale/Wanted 10 10-09-2007 11:25 PM
E36 Auto to ZF Manual Converstion larryglover@gulfviewllc.c E36 1 03-28-2007 09:59 PM
e36 auto tranny? Mercenary(FH) E36 12 12-27-2006 12:00 PM
