Unread 02-07-2009, 11:18 PM   #1
falak sher
Your Ride: 1992 bmw e36 316i
poor idle in when the engine is cold??
hey guys i have a 316i e36.
my car doesnt idle properly in the mornings but when it runs for a bit it becomes fine.
what might be the problem?
Unread 02-10-2009, 10:50 AM   #2
jarda
Your Ride: e36 318iS coupe
This can have lots of reasons. Do a visual check of all air hoses around the engine and then go to the dealer for diagnostics.
One other thing you can do by yourself is disconnect the volume air flow sensor while the engine is running - if the engine starts going crazy then the sensor is ok, if not, it is blown.
In my case the cause was the lambda sensor.
Unread 02-10-2009, 01:37 PM   #3
falak sher
hey bro thanks ill try whatever u have mentioned and will give u the feed back
Unread 02-13-2009, 10:32 PM   #4
falak sher
hey guys i fixed quite a few vaccum hoses its become a bit better, but jarda mentioned something abt the lambda sensor, any idea whr its located?
Unread 02-15-2009, 04:00 PM   #5
jarda
its stuck into the exhaust from the side.. number 16 on this picture http://bmwfans.info/original/E36/Cou...8/ill-18_0213/
Very rough explanation of its function:
it measures amounts of some chemicals in the exhaust fuels and sends this info to the engine's control unit. When the info is wrong, the unit can send wrong amounts of gas and air into the valves causing weird behavior, i.e. rough idle..
The best way to check the lambda probe is to go to the dealer for diagnostics - lambda probe errors will show up on their computer. In my case the lambda sensor reported wrong values only when the engine ran over about 4000rpm so when I returned after a long trip on a highway (lots of errors), the idle was all messed up, but running around the city (not many errors) it was just fine.
Unread 02-16-2009, 07:20 AM   #6
falak sher
hey man thanks for the info. ill get it checked and will get back to you. cheers!
Unread 05-19-2009, 04:44 PM   #7
1985 325E
1985 325E's Avatar
Your Ride: 1985 325 E
WTF is this thing called? I have been trying to find a replacemebnt, and it seems that NO one knows what the hell it's called. Been trying to find a replacement online, but again the "naming" of the part is different depending on who you are going through.
Seems I can't figure out how to attach a photo. E-Mail me to see what the hell I am talking about.
donovan.carrick@gmail.com
Unread 05-20-2009, 04:46 PM   #8
It called a LAMBDA probe or sensor in some countries and on some makes/models. It's called and O2 or Oxygen sensor in other countries. 85 325e should call it an oxygen sensor. As discovered in an earlier thread the 316 calls it a LAMBDA. Does the same thing, compares oxygen levels in the exhaust stream with oxygen levels in the atmosphere and then sends that info to the computer which determines fuel trim. Or is it a different part? can you reference the number in the diagram Jarda posted?
Funky Sound comming from engine. doughboyea E46 7 09-12-2006 09:23 PM
Trouble starting car after sitting cold for 3 days..help!? delmarco E36 2 05-28-2005 09:26 AM
