Unread 02-05-2009, 08:09 PM   #1
528i tourer
Your Ride: 528i touring 1998
Steering wheel vibration when braking at 80 km/h
Well when braking at about 80-120 km/h, my steering wheel vibrates, below 80 no problems.
What can it be ?
Thanks!
Unread 02-06-2009, 09:16 AM   #2
Some guesses... suspension bushings, control arms, tie rod ends, brake rotors, wheel balancing. As for your gearbox vibrations, maybe transmission or motor mounts, more remotely the driveshaft, has there been any damage to the undercarriage?
Unread 08-07-2009, 05:50 PM   #3
egenyru
egenyru's Avatar
Your Ride: 1992 bmw 318i
I had the same problem. The reason of vibration was the brake rotors .Hope this helps.
Unread 08-08-2009, 12:55 PM   #4
Matty D
Matty D's Avatar
Rate My Car: 218 / 340
Your Ride: 1994 740i
Had this problem for years and found a simple solution, If you do not have standard bmw wheels they will require Spiggot rings! I thought this is too simple to solve my problem but it worked! Most tyre and wheel garages have these ring sets so they are not hard to get hold of. My vibration was driving me nuts for so long hope this helps ya.
Unread 01-28-2010, 12:44 PM   #5
karime302
Your Ride: E30 M3
I THINK IT THE control arms
Unread 04-23-2010, 02:21 PM   #6
I had a similar issue, it ended up being worn wheel bearings although anything mentioned above is possible.
BMW e46 steering wheel adaptor dilemma badazz3001 E46 0 01-28-2009 04:12 PM
Steering Wheel Issues 525mike E12, E28, E34, E39, E60 1 03-26-2008 05:24 PM
vibration when braking Davey D 67 E46 2 06-14-2007 09:15 AM
steering wheel cruzin 323is E36 17 04-26-2005 06:18 PM
