Unread 01-17-2009, 07:14 PM   #1
QcMarque
QcMarque's Avatar
Your Ride: 1994 740i
Question ECU Issues?
So I was doing some research and found that the stock ECU (#1 267 355 796) doesn't have an upgraded version (BavAuto, FunCar.ru, etc I'm unable to find anything)... though I'm told the car I just bought has an upgraded/performance ECU in it, and the stock EEPROM is in the glove box.
Curious, I went to pull the ECU but didn't have the sockets to do it. I plugged it back in and went about my evening. Next time I started the car (or even turn the ignition on) it runs through a bunch of diagnostics stuff (Software Ver, BMW NR, some other NR thing, and some other stuff), the dials run up and back down, then the display goes solid and doesn't change.
To me, this seems most peculiar and it shouldn't do that. Any thoughts? I'm going to go ahead and pull the ECU and open it up, put the stock EEPROM back in and see what she does.
I do have a BavAuto code reader and it's not throwing any codes... so I'm a little stumped.
Thanks everyone!
Canadian by blood... German by ride
Unread 01-27-2009, 03:58 PM   #2
QcMarque
QcMarque's Avatar
Here's the information that the display shows everytime I turn the key to Position 2(doesn't matter if I start the car or not):
BMW NR 1388757
CODE NR 23096
K-ZHAL 7296
F.G. NR BF 09611
SW VER 0.83
ND INDEX 08
If I put the ignition in Position 1 and leave it for about 8-10 seconds the dash display changes languages (English US, English UK, French, Itanian, Spanish, German). It only changes 1 language at a time, so I have to keep turning the key off and on to get it back to English.
ecu problem..realy need advice fourtwenty E36 5 01-20-2008 04:24 PM
M42 318 Wont Start. ECU problems? Numark318i E21, E30 3 10-14-2007 03:08 PM
ECU location maximk2 E36 3 05-27-2007 12:57 PM
Time for a new ECU DME POS_BMW E36 8 07-10-2006 03:08 PM
Update on cams, advice on ECU PLS Rooz E36 71 09-05-2005 08:16 PM
