Unread 01-09-2009, 09:17 AM   #1
tree36
tree36's Avatar
Rate My Car: 284 / 340
Your Ride: 1993 325i e36
Control Arm or Power steering??
Okay so about 2 weeks ago i started to hear a funny almost rubbing sound from my steering. it usally only happens when i push my car or let the rpms go alittle high. and then when i stop and make a turn i hear a strange noise and the steering seems harder. So is it the power steering fulid or control arms? also can i replace my power steering fluid with mobil 1 synthetic ATF? ive heard it before but am not positive
Unread 01-11-2009, 04:31 PM   #2
petriti
petriti's Avatar
Your Ride: BMW
If your steering makes strange noise in both ways, so right and left, for shure is the lack of the steering fluid, and you must add the fluid.
As far as I know (according to the my readings regarding the oils).
Mobil 1 Synthetic ATF is a multi-vehicle formula recommended for use in modern high performance automobiles, SUV's,
SUT's, vans and other light trucks requiring Mercon V performance levels
Recommended by Imperial Oil l for use in 2005 and earlier GM vehicles. Mobil DEXRON-VI ATF is recommended for 2006
and newer GM's and for improved performance in 2005 and earlier GM vehicles
Also recommended Imperial Oil for Fords that require a MERCON V fluid and for pre 2000 model years Ford light duty
vehicles.
Surpasses the off-highway power transmission requirements of Allison C-4
Suitable for Caterpillar TO-2 applications
Recommended for use in any power steering unit where an ATF is required
I hope that this will somehow help you.
tI'm not just Perfect, I drive BMW too
Unread 01-12-2009, 09:13 AM   #3
tree36
tree36's Avatar
alright thanks. yeah im gonna go ahead and try the mobil 1. we'll see what happens i hope this is all my car needs.
Unread 11-01-2010, 08:10 PM   #4
krislou80
Your Ride: 2009 BMW 323i
If you're already having a hard time managing your vehicle when you make turns, then its likely that one of your control arms has been compromised. Inspect your control arms for signs of wear and tear, and if one of them is in bad shape, then promptly replace it with a new control arm . if you are referring to on the actual steering wheel, then some grinding noise is normal. it's possible the electrical contacts for airbag/cruise/radio controls, whatever you have on the steering wheel are making some grinding noise.
Unread 11-01-2010, 09:18 PM   #5
amath80
Your Ride: 2006 BMW
control arm regulate the movement of your front wheels each time you turn or corner. That way, your wheels can move without the risk of over steering.
Unread 11-07-2010, 10:44 PM   #6
Not sure what a rubbing sound sounds like. If you have a hydraulic pump whine, I would suggest pulling off the reservoir and cleaning the screen when you replace the fluid. I could not get my reservoir in two without breaking it, so I just flushed it several times with paint thinner. I put standard ATF back in it and the noise went away. I also replaced the power steering hoses and the hose from the PVC valve to the oil pan to get rid of those pesky oil leaks while I was under there. BMW does not carry the PVC hose, because a standard hydraulic hose is better than the original part and fits it.
Could use some guidance Door locks, power steering issues new2330i E46 0 12-31-2008 12:35 PM
Changed My Power Steering Fluid Numark318i BMW OEM Parts Department DIY's & FAQ's 2 11-01-2007 01:59 AM
tough time with control arm maximk2 Tire, Wheels And Suspension Forum 10 10-30-2007 12:48 AM
Power Steering Fluid Showing on the VDO Jimmie34 E12, E28, E34, E39, E60 4 05-09-2007 09:15 AM
