Unread 12-03-2008, 11:30 PM   #1
tree36
tree36's Avatar
Rate My Car: 284 / 340
Your Ride: 1993 325i e36
Exclamation Fan, Radiator, antifreeze HELP!
Ok so when I bought my car it needed a few things. Water pump, Fan clutch, fan blade, radiator. I replaced them all myself to save so money and for fun. Not that hard anyway. Okay so I bought the car in like August and did all this work. Everything’s been fine since then. Until tonight. Went to the store and when I got home it my engine was smoking im like ahh . So I pop it and the air smells of antifreeze. My Fan blades are completely gone well there are bits and pieces about the engine and there are some good dents in the radiator. Oh and there was a steady flow of antifreeze from the bottom of the radiator and my coolant is pretty much gone. (I had checked the coolant about 3 days ago and it was fine) WHY did this Happen? PLEASE HELP! I can replace the fan blade and probably need to get a new radiator (not to big of a deal) but I just don't want it to happen again!
HELP ME!
Thank You
Unread 12-04-2008, 02:15 PM   #2
tree36
tree36's Avatar
i don't wanna replace it and it just happen again. im really stuck here. thinking of a fan delete prehaps?
Unread 12-04-2008, 06:19 PM   #3
motorwerks
Title: Sitting in Time out
Rate My Car: 165 / 340
Your Ride: '97 328i
It sounds like your fan already deleted itself, and took the bottom of your radiator with it. This is unfortunately all to common with these older cars. The old fans get brittle, and break off at high rpm's. A new one will probably take another 10 years to break. You will sadly need a new radiator from the sounds of it, and a new fan. You can use this opportunity to do the clutch fan delete mod if you like, either way you need to get a fan in there.
Unread 12-04-2008, 10:28 PM   #4
tree36
tree36's Avatar
the fan was 3 months old same with fan clutch and radiator
Unread 12-04-2008, 10:32 PM   #5
tree36
tree36's Avatar
i wasn't running it any harder then a normal 18 year old would
Unread 12-05-2008, 09:14 AM   #6
motorwerks
Your Ride: '97 328i
wow, sounds like a faulty fan. That really sucks... If you want to be sure that never happens again then fan delete is the way to go.
Unread 12-05-2008, 09:41 AM   #7
tree36
tree36's Avatar
yeah it dose suck. i bought the fan from a bmw dealership maybe they might give me a refund haha i found the piece with the bar code on it. somehow. but i doubt it i mean come its a bmw dealership. yeah fan delete is what im doing. anyone got a good site i can order it from. also is there any DIY for the fan delete?
Thank You.
Unread 12-05-2008, 05:10 PM   #8
motorwerks
Your Ride: '97 328i
Unread 12-18-2008, 11:08 PM   #9
tree36
tree36's Avatar
did the fan clutch remove. all is well. i actually think i can feel some gain from not having the heavy mech fan on. or it could just be i haven't driven in awhile haha
The Case of the Rogue Fan Carmine-i United Off Topic  **FOR MEMBERS ONLY** 16 10-05-2007 09:04 AM
aux fan nij E12, E28, E34, E39, E60 2 04-01-2007 04:54 PM
electric fan won't stop! dead batterys suck! bmw_passion E36 6 01-05-2007 05:10 AM
Need Condenser/Aux Fan Chevell E36 10 08-23-2006 12:55 PM
fan whine Spieluhr E36 5 05-17-2005 09:30 PM
