Unread 11-19-2008, 02:18 PM   #1
Stuart Ritchie
Your Ride: 1996 E38
Unhappy Cannot get in!
Hi all, I have a 96 E38 740iL
This morning I tried to get in, (tried both of my keys) but nothing happens, nothing at all. The little red led on the key glows as usual on both keys but not a glimmer of life anywhere. No clicks or anything. Dead.
Cant get in with key in keyhole either, at least I dont think I can.
Does anyone know what to do next, surely I dont have to call a megabuck mobile service co to get me in?
Is there a way to unlock manually? A secret button or something
Can't even get in to the boot its all electric too!!
Unread 08-13-2009, 02:59 AM   #2
mantonio
Your Ride: 99 bmw 740i
hi stuart, your battery is dead.if it's in the trunk,charge the battery or put jumper cables on to recharge the battery. if not,get a small child to go through the trunk & pull your hood latch.good luck
Unread 08-13-2009, 05:11 AM   #3
Stuart Ritchie
Your Ride: 1996 E38
Angry E38 electrical headaches
Mantonio
Thanks for your reply. You are quite right, dead flat battery. That leads me to the next question, i have a lot of circuits that are draining the battery and so I pulled some fuses out (eg car computer and a few other non essentials) this lower the drain down rate but still drains some fractions of an amp.
Any case now the battery is actually stuffed and I cant get it to charge up, and I havent driven it for some time, seems a shame to say but Ive never had any Japo cause such electrical grief.
I guess I need to buy a new battery and get it started and take it along to auto shop and pay big bucks to get going again.
Do you know of any good on line guides to electrical problems or where to get the full wiring diagram?
Unread 11-11-2010, 10:12 PM   #4
7seriesmax
7seriesmax's Avatar
Rate My Car: 245 / 340
Your Ride: 1989 735 is
pop the clips on your grill(use a flashlight and a thin screw driver) and release the hood with a screw driver tip then charge that battery.
Unread 12-09-2010, 09:17 AM   #5
Shled
Shled's Avatar
Your Ride: '01 Dinan 7 s3
Turn the key to the left. Then keep turning. It will unlock (trunk or door).
...on the gas,
Shled℠
Charter Member
BMW E38 Real Beef Club
'01 Dinan 7 s3
Check the WTB list (updated):Looking for: Looking for
Alpina Softline Classics, L&R REAR dual pane glass (and gasket); Picnic tables (for black leather interior) with mirrored headrests, rear A/C control unit, rear cold compartment,
http://tinyurl.com/38625fv
Unread 12-09-2010, 04:17 PM   #6
DavidBlaine
Your Ride: E30
Was there anything not working/intermittently working before you had the battery go flat?
Nadeem
Unread 02-24-2011, 08:36 PM   #7
cjlopez956
Your Ride: 1994 740i
Jack up the car and connect the + side jumper cable to the starter post and - to the frame. Do not try to start the car or charge it. This should give you some power so you can unlock your doors.
Unread 11-10-2011, 10:58 AM   #8
xecconlight
Your Ride: 2010
Turn the key to the left. Then keep turning. It will unlock.
