Unread 11-07-2008, 10:07 AM   #1
535ie39
Your Ride: bmw535i
auto transmision gear change issue?
my 5hp24 auto experience a probelm like this:
normally when you leave the foot from gas, the auto gear box should stay in high gear to let the car run freely. but my auto box will stay in that ever gear it is, so the car will slow down fast. the car has done about 100,000miles. no fluide or filter ever changed. other than this 'probelm' . the car drives OK. waht could be the cause? should I get the fluide and filter replaced? does this show the sign of series problems ....?
Unread 11-27-2008, 02:59 PM   #2
guidomaas1974
Your Ride: '02 e39 2.9dA
Hi,
The remedy for your problem is a fluid/filter change.
Best would be to have the fluid replaced first without the filter. Only about 60-70% of the fluid can be drained each time due to the torque converter containing the rest. After the first time fluid change drive about 2000 miles, then have the fluid, filter and gasket replaced as a complete set.
Make sure also to clean the magnet on the gear box pan.
The dealer ship will tell you that the fluid doesn't need replacement due to application of life time oil. disregard the advice and replace the fluids.
Guido
Unread 11-28-2008, 01:49 AM   #3
535ie39
Your Ride: bmw535i
Originally Posted by guidomaas1974 View Post
Hi,
Guido
Thanks for the advise. I just had both filter and fluid changed about 400m ago. since then , the problem never come back again. the car has done 150,000km. the fluid looks a bit dirty/dark, and there is no visible metal shred around magnet. only things like dark /sticky glue type things. clearned everything. car drive great. FYI, I bought fluid from AUdi ( same 5hp24 Autotrans) about half of BMW's price. The mechnic told me that the real problem was not the old fluid, but the dirty filter which can only have half of the capacity. so if you drive hard, there wont be enough oil to the mechnical parts.......I opened it, it was......terrible inside. MUST have filter changed in about 70k miles
E39 auto gearbox fluid change bmw535i E12, E28, E34, E39, E60 1 10-14-2007 02:21 PM
Something New At Premium Auto Care Dwayne@PremiumAutoCare Detailing and Cleaning 1 09-19-2005 11:55 AM
