Unread 10-30-2008, 04:48 PM   #1
dick c
Your Ride: 1995 540i
Question E34 A/c Heat Issue.
E34 A/c Heat Issue.
Hi . I'm A Newbie At This So Here We Go. I Have A 1995 E34 540i, When The Ac Is On I Can Get Heat From The Center Right Hand Vent With Cold Air Blowing From Left Center Vent. Anyone Seen This Before? How Do I Fix? Other Vehicles I Would Say It Would Be A Blend Door Problem. I've Been Told That Does Not Happen . Ac Will Blow Cold From Both Vents Until Engine Gets To Temp.
Unread 11-12-2008, 08:51 PM   #2
Antiburn
Antiburn's Avatar
Rate My Car: 193 / 340
The water control valve has jammed open causing hot antifreeze to constantly flow through. If you open your hood the valve assembly is located directly next to the fuse box. Try tapping on the solenoid valves with a small hammer and possibly might free it up.
E34 A/c Heat Issue. dick c E12, E28, E34, E39, E60 3 10-17-2008 05:54 PM
oil or oil from A/C ??? rawhawk E36 2 03-09-2008 08:08 PM
No heat. I NEED heat! M.C. Sketuls E21, E30 9 10-22-2007 06:53 PM
