Unread 10-09-2008, 09:18 AM   #1
donleycott
Your Ride: 1995, 1997, 2007 BMWs
Check Engine Light OBD code 0800 - Help
I have an E36 and I am getting a check engine light and the code is P0080 which according to my manual is Exhaust Valve Control Solenoid Circuit High.
Does anyone know what is causing this?
Thx
Pat
Unread 10-09-2008, 09:34 AM   #2
C Sean Watts
Name: C Sean Watts
Your Ride: 1997 328is and others
Thx
Pat
Bad control solenoid and/or the circuit that controls it.
Unread 10-09-2008, 09:40 AM   #3
donleycott
Thanks, could you help a bit more, what is a control solenoid? I see that description in my OBD code book but I cant find a part on the BMW that has that description
Unread 10-09-2008, 01:30 PM   #4
C Sean Watts
Name: C Sean Watts
The best thing to do when you're learning
is to get a good repair manual. Bentley publishing prints good ones
http://www.themotorbookstore.com/bmw...1992-1998.html
I'm looking at your bio line and if the car you are talking about is 2007, it isn't an e36.
Unread 10-09-2008, 02:10 PM   #5
donleycott
I should fix the BIO, I have a 95, a 97 and a 2007.
I also have the Bentley repair manual for the 95 and 97
Pat
Unread 10-09-2008, 08:56 PM   #6
C Sean Watts
Name: C Sean Watts
Solenoid is a small non circular type linear electric motor. It moves in a short straight line motion. Are there any engine running and driving issues with your car, or is it just a light (CEL)?
Unread 10-10-2008, 12:02 AM   #7
donleycott
The engine does not idle smoothly, it seems to idle at a lower speed than it used to.
Where is this solenoid, what does BMW call it?
Thank for helping
Pat
Unread 10-10-2008, 09:05 AM   #8
C Sean Watts
Name: C Sean Watts
Honestly,
Thank for helping
Pat
With no more than a code reader, it will be very difficult to troubleshoot a poor idle. In order to glean any good info from a forum, be as specific as possible and provide info like; year, engine, miles, exact conditions when the problem occurs, cold, warm, hot, what makes it better, what makes it worse, what you have checked/tested, or not, what corrective action you made, etc.
You will tend to get better answers that way. What you describe now sounds like a vacuum leak.
There are multiple posts that go something like, "I replaced part 'X' with a known good replacement and the problem didn't go away."
Later the 'known good replacement' was replaced with a new dealer part that fixed the problem. So it isn't hard to see fault in how to fix something in the forum?
As for finding it on the engine, a good, high quality manual or realoem.com will have pictures - a picture is worth a thousand words.
Reset the code memory and see how long it takes to come back.
318i Check Engine Light Code 60 pjmmarine E36 0 02-06-2008 05:48 PM
OK - getting codes, CHECK ENGINE light works, but it's not on! volvodefector79 E36 1 11-13-2007 06:46 PM
Service Engine Soon (OBD II) light donniemac E46 2 05-09-2007 10:12 PM
