Unread 10-01-2008, 09:08 PM   #1
chris3896
Your Ride: 2000 323i
Coolant Leak - Expansion?
So my 2000 323i's engine started to overheat and I noticed that there was an explosion of coolant all over my engine bay. I waited till the next day and slowly poured some coolant into the expansion. I waited a few seconds and coolant slowly leaked down from the bottom of the expansion onto the plastic underneath. I've been told that the radiator might need to be replaced but it seems like the expansion is really the only thing that is damaged. Just because the coolant leaks out of the expansion, I could probably just replace that. Does that sound right to anyone? And does anyone maybe have a tutorial or can lead me through the removal? It doesn't seem too hard. Thanks.
Unread 10-18-2008, 07:55 AM   #2
oz striker
oz striker's Avatar
Your Ride: E46 330ci, E30 325i
sounds reasonable to try and jus change the expansion tank at first. how many miles have you done? I had a gradual coolant leak, never really overheated jus needed topped up every week or so and i 1st had the expansion tank replaced, but turned out my radiator matrix was all swollen and past its best, hence had that changed as well.
If you do get the radiator changed, it worthwhile changing the water pump, thermostat and drive/accesory belt also.
Found this DIY of sorts over at E46Fanatics:
http://forum.e46fanatics.com/showthread.php?t=208898
Hear my favourite mod: http://uk.youtube.com/watch?v=EyUjiPV6jtM
Unread 10-20-2008, 02:13 AM   #3
chris3896
yeah definitely the expansion tank. massive crack down the side haha. I didn't even notice it until after i took out the entire thing. It was a pain to get everything out but it really was more manhandling than anything. thanks to Rob for the help.
Unread 12-02-2008, 06:38 AM   #4
chris3896
yeah so we replaced the expansion tank and now it's still overheating. it's fine for the first five minutes then it blows up again. anyone have any other ideas?
Unread 12-02-2008, 10:05 AM   #5
motorwerks
Title: Sitting in Time out
Rate My Car: 165 / 340
Your Ride: '97 328i
I had nearly the same thing happen to me, and it was the waterpump. The pressure from overheating is probably what cracked your expansion tank. It is possible it's not the water pump, but rather the thermostat. Either way you'll need to get in there to find out which one it is.
Unread 12-11-2008, 03:17 AM   #6
chris3896
i'm also not getting any heat inside the car which is kind of ironic since my engine is practically blowing up...does that narrow it down any?
Unread 12-12-2008, 03:29 PM   #7
motorwerks
Your Ride: '97 328i
If your pump isn't pumping, then no heat to the heater core. I stick with my story.
Unread 01-02-2009, 05:47 PM   #8
brinkley
Your Ride: e46, e30, MR2 T
I am fighting the same issues. My expansion cracked the other night. i went from no heat to only heat before it went out.
you may have a stuck thermostat as well. I have heard that there is a water temp sensor at the back of the block that can also go out and cause the thermo to not open.
#3 in that photo
Also a stuck water valve could be causing you to not have heat
#2 in this one
Unread 08-25-2009, 10:04 PM   #9
zach22
Your Ride: 2002 325i
I had simalar issues with my 02 325i. Started to over heat and had coolant leaks. did a coolant flush and replaced the main drive belt, water pump is what caused the leaking and overheating. One of the bearings went out. I recomend changing the water pump. it could be leaking from the weap hole on the underside. luckily i caught it before the expansion tank took a crap
Coolant Leak, Fuck (long post) bartb E12, E28, E34, E39, E60 0 03-22-2008 12:25 AM
'03 325i Coolant Leak Jab42684 E46 1 12-03-2007 10:53 PM
Coolant Level Mercenary(FH) E36 5 10-27-2006 02:37 PM
Coolant bleed problem - 1997 540i zole2112 E12, E28, E34, E39, E60 7 10-23-2006 06:55 AM
Holy Crap . . Coolant leak! Dudesky E36 5 08-05-2005 10:42 AM
