Unread 09-28-2008, 02:23 PM   #1
SeanP01
SeanP01's Avatar
Rate My Car: 239 / 340
Your Ride: 1992 525i
Question Stereo Code
Hi all-
I have a '92 525i and I recently replaced the battery. Well, of course, the deck deactivated and I need a code to set it right. I don't have the owner's manual, but I think the deck is factory (it's a BMW stereo with CD changer).
Does anyone know of a way to retrieve this code or bypass it? I really don't want to have to buy and install a new deck...
Thanks!
Unread 09-28-2008, 07:36 PM   #2
mzbmw325i
mzbmw325i's Avatar
You can go i think to a local bmw dealership with your vin and ask for it, i don't know if there is a charge for it or not, but they should be able to retrieve it, then write it down somewhere safe, anytime you disconnect or replace your battery your codes will erase on your factory stereo, it's anti theft measure.
Unread 09-28-2008, 07:40 PM   #3
SeanP01
SeanP01's Avatar
Thanks! I'll try calling one tomorrow and check on that.
Unread 09-29-2008, 06:55 AM   #4
MBD506
Your Ride: 1995 325is and 1994 325i
You need to remove the radio. To remove it you need a 5-sided tool for the task. On the back there's the serial number stamped to a small plate, then call the dealership so they can give you the radio code.
Unread 09-30-2008, 10:36 AM   #5
SeanP01
SeanP01's Avatar
Thanks!
Unread 01-28-2010, 04:24 AM   #6
karimMsalama
Your Ride: BMW M5 VW MK2
what about the local bmw dealership
Unread 03-13-2011, 07:58 PM   #7
daveinsd7
Your Ride: 525i sport wagon
Having an issue with my 1995 BMW 525i. I imputed what I thought was code. Code screen has 4 spaces but I have a number that has 5 digits. And on top of that the alarm sounds and have to disconnect battery every time.Car will not start. Can someone help? Thx.
BMW flash code max79 E36 14 03-10-2012 09:42 PM
Radio Code mrkbik E36 16 03-13-2011 09:48 PM
Peak Code which I dont understand. Help! kvadgama E36 1 06-08-2007 12:36 PM
Stereo or gauges?? akinthecat E36 7 03-29-2007 10:33 PM
Ran my code reader this morning before my appointment - 3 new codes billycuth E36 8 06-28-2005 07:41 PM
