Unread 03-22-2008, 02:29 PM   #1
f0rbes
Your Ride: 1986 524td
Vacuum problem
Hi, I am new to these forums as I just came across them today . Anyways I have a minor problem that I need advice on fixing. Basically I have a 1986 524td. My problem is that my brakes arent getting enough vacuum and its causing my brakes to be very squishy so i have to really stomp to get my brakes working. I have realized that maybe the brakes arent getting enough vacuum because maybe the booster is recieving most of it to help get better performance because let me say, for a diesel this thing runs like a beauty.
What I was thinking was installing a seperate vacuum pump where i have extra space (already found the perfect spot) and hooking it up to where all i need to do is flip a switch or somesort if I find my brakes are getting squishy and it turns the vacuum on and then a couple seconds later I turn it off and my brakes are fine and so on and so forth. But I was also trying to think of a way to make it run automatically.
Basically I am wondering of any other possible solutions or maybe any advice on fixing my brakes. Thanks.
Unread 03-22-2008, 02:36 PM   #2
Have you tried replacing the brake fluid? I'd also try bleeding the system for air and checking for leaks.
Unread 03-22-2008, 02:45 PM   #3
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 255 / 340
Your Ride: 1997 328i
If you had a vacuum problem with the brakes & brake booster, you would have a stiff pedal or find it difficult to press down on the brake pedal! Squishy brakes sounds like air in the brake system or bad master cylinder!
http://autorepair.about.com/od/troub...s_brakes_2.htm
http://autorepair.about.com/od/troub...s_brakes_4.htm
Unread 03-22-2008, 06:58 PM   #4
f0rbes
Its hard to explain what kind of feeling i get when I press on the Pedal but basically It feels like I am just not gettign enough vacuum to the brakes. Ive replaced all the hoses with new ones and there isnt any blockage or holes/leaks. I was going to do brake fluid once the weather got a little nicer and from the reciepts the booster is fairly new. oh and the brakes are firm not sqishy my fault on that.
Unread 03-22-2008, 10:44 PM   #5
JetBlack328i
JetBlack328i's Avatar
Rate My Car: 69 / 340
Your Ride: 96 328i
+1 check for air in the lines or a bad master cylinder
Unread 03-23-2008, 01:38 PM   #6
m3flyer
m3flyer's Avatar
Rate My Car: 3 / 340
Your Ride: 1) Alpinweiss 1989 M3 2) Diamondswartz 1989 M3
Thumbs up Ding !!
2nd.
Johnny is correct.
Although loss of the booster entirely may result in weak pedal as well.
Also... check the master cylnder.
Try a synthetic Dot4/5 fluid and flush 'til the bubbles disappear.
Carpe Diem
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 09:50 PM
328is problem, runs weird - Vacuum hose leak? something clogged? peterkdenny E36 4 02-16-2008 11:27 PM
325 brake light problem fgmx Lighting 2 02-01-2008 02:52 PM
