Lighting
Sponsored by: BavToys.com
Unread 03-21-2008, 06:57 PM   #1
caperry
caperry's Avatar
Rate My Car: 264 / 340
Your Ride: 1985 BMW 735i
Turn Signal fuse blows every other day
Question? Any ideas as to why mu turn signal fuse would blow an average every other day? I had the car in for a service and they replaced the bulb which I had heard somewhere that when the bulbs go out it can short the fuse. Anyways, they replaced the bulb and fuse, I am not convinced that that was the problem because the fuse blew again a few days after. Could it be that I have another bulb blowing? the Hazards work fine, kind of. when I press and hold the hazards in all lights light up, but when I let go, only the left lights light, unless I put on my right turn signal? GREMLINS I SWEAR!!
Anyways I feel like an obnoxious driver when I can't signal.
Cyrus
1985 BMW 735i----245k mi
Unread 03-21-2008, 07:00 PM   #2
That seems like a loose wire causing a short now and then. Is there any water or dampness in any of the lights?
Unread 03-21-2008, 07:22 PM   #3
caperry
caperry's Avatar
that was my first inclination, I guess I just have no idea of where to start. A few months back the rear brake light had water in them, and I was also getting water in the trunk and inside the car, so I had the whole inside of the car torn out to fix it. I did notice some water in them then, but I have sealed them up with silicon since then.
Cyrus
Unread 03-21-2008, 08:21 PM   #4
Maybe there is some corrosion that has created a short then.
Replacement turn signal bulbs exjarhead328 Lighting 7 03-21-2008 09:24 AM
325is turn signal stays on [ stuck] ?? gout33 E36 6 08-13-2007 11:41 AM
For all of us who like to wast time at work projal147 Comedy Collection
21 02-07-2007 11:51 AM
Signal light malfunction bmw4me E36 9 10-06-2006 05:27 AM
e36 ellipsoids intall guide 94bmw325i Lighting 3 09-20-2006 11:53 PM
