Unread 03-16-2008, 07:05 PM   #1
guilty1
Your Ride: 1985 318i
powertrain swap
I have 2 BMW
1) 1985 318i 2 door 5 spd
2)1986 325e 4 door 5 spd
Can the owertrain AND the driveshaft be taken out f the 4 door and put into the 2 door?
Will the driveshaft be too long or would I have to reuse the driveshaft from the 2 door?
Unread 03-16-2008, 07:51 PM   #2
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 255 / 340
Your Ride: 1997 328i
Originally Posted by guilty1 View Post
I have 2 BMW
CALL DINAN & ask them!!! 800-341-5480. Tell them you are UB member you would like to know if it is possible!
Unread 03-16-2008, 07:52 PM   #3
Antiburn
Antiburn's Avatar
Rate My Car: 193 / 340
You will need to change the front subframe, drive shaft, instrument cluster, and possibly redrill rear trans mounts but it might fit. You would want to use the same diff. Auto's tend to have a better gear ratio then manuals which you can find out at realoem.com what the ratios are.
Unread 03-16-2008, 07:53 PM   #4
johnnybayonne
+1
http://www.realoem.com/bmw/select.do
Unread 03-16-2008, 08:03 PM   #5
guilty1
Antiburn.
Both cars are 5spd.
I thought both cars used the same body platform?
Unread 03-16-2008, 08:18 PM   #6
They do, but sub frames and mounting points will be a lot different between a 4 and a 6 inline.
Unread 03-16-2008, 08:26 PM   #7
guilty1
I have the cross member from the sedan..but what you are saying is that the cross member may bolt in a diferent location on the sub-frame?
Unread 03-16-2008, 08:58 PM   #8
It's possible.
Unread 03-17-2008, 05:34 PM   #9
Antiburn
Antiburn's Avatar
The only difference that Im aware of with the subframes is that the engine mounts are different from 4 to 6 cyl. The 4 main mounting holes should all line up with no problem.
The issue with the rear trans mounting holes is that the 4cyl trans could possibly be shorter, but knowing BMW from that era almost everything is interchangeable. Easyest way to find out before dropping eather trans's is to measure from a given point off the frame rails.
Unread 03-17-2008, 09:07 PM   #10
guilty1
Thanks Antiburn!
I tried the link to the realoem.com but it did not give me the specs on the rear final drive ratio,
Do you know of a site that may have this info??
Time to get started on motor swap... TheUniballer E36 13 12-30-2007 12:26 AM
figuring out an s52 swap TheUniballer E36 5 08-13-2007 10:51 AM
84 533/ 86 535 Drivetrain swap jonny E12, E28, E34, E39, E60 5 05-21-2006 11:58 AM
318 S54 swap? Storamin United Off Topic  **FOR MEMBERS ONLY** 2 04-30-2006 10:16 PM
I finished the engine swap htp.bmw E21, E30 7 06-21-2005 11:33 AM
