Unread 03-16-2008, 12:04 AM   #1
318ie21
Your Ride: 318i E21 1980
E21 ignition switch....HELP!
Hi all, can someone tell me how to change/replace the ignition switch, have taken the retaing bolt out but the switch still won't come out.
Unread 03-16-2008, 03:55 PM   #2
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
Is the switch busted or is it not letting you start the car? Pulling out the tumbler where you put the key in is not easy to replace but the switch and wiring behind it is not that hard.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 03-16-2008, 07:59 PM   #3
Antiburn
Antiburn's Avatar
Rate My Car: 193 / 340
If you look where you insert the key you will find a small hole, about the size of a paper clip. Get a paper clip, straighten it out and put it into that hole. Insert your key, turn the key on and give it a bit of a wiggle back and forth and the cylinder should come out.
Spinning Ignition barrel repair David Mc E36 12 10-05-2011 10:00 AM
Backup Light Switch DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 9 05-31-2011 08:27 PM
E90 Push-Start/STOP Switch DIY....?? Kiterunner E36 29 03-07-2011 10:37 AM
330ci window switch njjeter E46 2 07-21-2007 04:11 PM
E21 Questions M3WannaBe E21, E30 6 04-07-2007 08:02 AM
