Unread 03-15-2008, 06:34 PM   #1
notallthere
Rate My Car: 259 / 340
Your Ride: 2001 325i
Send a message via AIM to notallthere Send a message via Yahoo to notallthere
how wide can I go
ok I have a 2001 325i sedan and was looking at getting a set of wheels I know a guy with a set of 18's with the 5x120 bolt pattern so they will bolt
the front are 18x8 with a 38 offset and 235/40/18's I'm not to worried about these the the rear has me worried
they are 18x9 with a 40 offset and running 265/35/18's and I think these are just too big but if they fit I would like to get them thanks for the help guys
Unread 03-15-2008, 07:46 PM   #2
Originally Posted by Rooz
Had a little time on my hand today...
Let's figure out the diameter of the factory setup...
Considering that 1 inch = 25.4 mm
Front: 225/25.4 = 8.8.....
8.8.... * .45 (45% of width is tire profile) = 3.9....
3.9... * 2 (top + bottom) + 17 (wheel size) = 24.97...
So the factory front setup is 24.97 inches tall
I'll spare you the explanations for the rear..
Rear 245/40/17 = 24.71 inches tall
Now, again.. I don't know too, too much if I'm correct but my guess is I need to come as close to those numbers as possible, right?
SO..... from what I calculated here's the closest setup I could think of on an 18" wheel....
Front: 235/40/18 = 25.4 inches tall
Rear: 255/35/18 = 25.02 inches tall
BUT... A 225/40/18 = 25.08 inches tall...HOWEVER being that the wheel is 8.5" wide (inside proportions so I am ASSUMING outside proportion is probably close to 9")
9" = 228.6 mm Meaning a 225mm tire would be too narrow for this wheel? AM I correct? And IF the wheel's INNER width is 8.5" then the 235/40/18 would be the proper setup, but if 8.5" is the outside width then 8.5" = 215.9mm, then the 225/40/18 would be perfect?
I posted that a long time ago, hope it helps
Unread 03-15-2008, 07:48 PM   #3
notallthere
thanks for the info but when it come to the conversions I'm ok I'm just more worried about rubbing with the width of the rear wheel
Unread 03-15-2008, 08:30 PM   #4
255's you'r safe
265's you may rub
Unread 03-15-2008, 08:36 PM   #5
notallthere
I wonder if anyone on here is running then I just could get these on the cheap but if I have to get tires it not such a deal
My car, close up, with a wide angle lens! mullethunter3 Bimmer Showroom 19 07-26-2006 12:46 PM
Looking for koenig Wide Body Kit e32 killer10 7 Series (E23, E32, E38, E65, E66) 1 06-15-2006 01:39 PM
Wide Body e_andres55 M3 21 12-27-2005 08:30 PM
sidebar too wide xsperf Site Feedback 7 10-23-2005 01:00 AM
Reuters Says Bush Photo Not 'Malicious,' Reports Wide Interest at Home and Abroad zeaq328i United Off Topic  **FOR MEMBERS ONLY** 1 09-17-2005 08:24 AM
