Unread 03-08-2008, 03:34 AM   #1
reymundo10
reymundo10's Avatar
Your Ride: 1995 325ic
Question No voltage @ fuel pump/ Bad Ground??
Any suggestions?
My car ('95 325ic manual) recently shut down while I was driving. It was similar to running out of gas. There was also a strange smell and smoke (very light) around the passanger floor compartment area.
Things I've tried:
-pulled fuel pump hooked up to 12v works fine
-checked relay (dme & fuel pump) with 12v across contacts, the normally open circuit was closed and continuity was restored.
- checked voltage @ fuel pump, leveler has power, pump when trying to start the car does not get power.
-ran jumper wires to get 12v from the headlight/foglight relay, got the pump started (heard the pump whirling) tried starting the car the noticable difference, cranks sounded stronger, but the car still wouldn't start.
Almost out of ideas, i'm going to pull the plugs to see if they are sparking but other than which i'm stumped. any help is 'preciated. thanks
Report Post Edit/Delete Message
Unread 03-13-2008, 05:15 AM   #2
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
If this failure was in any way associated with exposure to water, the DME may have been damaged. This link will help you to check the DME and its relay http://www.pelicanparts.com/BMW/tech...DME-Repair.htm
Unread 02-04-2009, 09:33 PM   #3
JoshsE36
JoshsE36's Avatar
Your Ride: 1993 318i 4dr 5sp
Yea, I had the same issue. My DME got some water in it from a heavy snow shower, (Snow melted & got in, parked for a week on my inclined driveway). Luckly, I had bought a replacment DME, becasuse this had happen to me a year before & the shop I took it to told me about this issue. They Dried it up & started back up. Try doing the same or you may have to by another unit. I got mine from: http://www.bmrparts.com/ Good luck.
fuel pump vIcKtOr9 E36 3 03-05-2007 02:12 AM
