Unread 03-07-2008, 06:48 PM   #1
Sheawind
Your Ride: 1995 BMW 325is Coupe
318is 1995 door lock problems
Just Got My New 1995 318is
But it has some lock issues
I can't lock my doors if it do then I wont be able to get in the car
I can lock the drivers side door with the key but it will not unlock the doors
The passenger side door latch is broken so it cannot be opened for the outside
The passenger side door lock only unlocks the passenger side door
And I do not know how too lock the trunk..
Can any1 help me.......
Shearwind@Gmail.com
Unread 03-07-2008, 08:36 PM   #2
Danucksjoe
Your Ride: M3 Cab
Open the trunk and you'll see a wire loom there between the trunk lid and body of the car. Open the tape and rubber boot protecting the wires of this loom. You most likely will see some of the wires inside pinched, burnt, and damaged. If so this is what is causing your grief.
Looking at the loom from the outside won't help assess problems as most of the time the wire loom shows no signs of physical damage. If repairs are needed, disconnect the battery first before working on the car otherwise, sparks and smoke shows will arise.
Unread 03-07-2008, 08:53 PM   #3
JetBlack328i
JetBlack328i's Avatar
Rate My Car: 69 / 340
Your Ride: 96 328i
possibley the door lock actuators bad?
Got Me A Bimmer 1995 318is Sheawind Introductions and Greetings 2 03-07-2008 08:47 PM
1995 M3 - $9000 mullethunter3 Bmw Cars For Sale/Wanted 7 02-10-2008 02:43 PM
1987 325 with Problems! NewBimmer E21, E30 4 11-06-2007 03:45 PM
FS: 1995 M3 w/ swap and goodies redefinedM3 Bmw Cars For Sale/Wanted 2 12-06-2006 12:25 PM
Carfax pls? bitcore United Off Topic  **FOR MEMBERS ONLY** 8 05-18-2005 02:55 AM
