Unread 03-03-2008, 01:03 PM   #1
320de46m47
Your Ride: 2000 E46 320D Auto
My tailgate glass wont open on my Touring (Wagon)
My tailgate glass wont open on my Touring (Wagon) and I suspect it's because the GMCU isn't coded right.
I don't want to pay 100 euros!!! (yes 20 second job and that's what theyre asking) to get it recoded when I might be wrong!
I know the motor and the lock work as when I bypass the relay it works fine
My question is ..how much current would need to be supplied to the relay trigger terminal if i bypass the gmcu?
it's pin 31 from plug x253 and it's a white and blue wire (RERHS) which goes to pin 4 on the relay. my gmcu is (i believe) not coded to supply an appropriate current so if i can find an alternative (live when the car is unlocked) and use the tailgate window switch to complete the circuit i should be in business
Unread 03-04-2008, 03:35 AM   #2
320de46m47
forgot to mention that i did change the relay too.
current to trigger passes along a 0.5 mm wire so needs to be very small
Unread 03-04-2008, 03:00 PM   #3
320de46m47
ive superimposed the trunk release switch diagram here and added a relay
the power to pin 4 on the tailgate glass relay is now supplied via the new relay 30 from the trunk release switch (small diagram). the relay is triggered by grounding 86 courtesy of the original switch supplied by ????? at 85??
Unread 03-04-2008, 03:35 PM   #4
320de46m47
the trunk release button supply (red line grey and red wire) is no good it dims the interior lights!
Unread 03-05-2008, 07:27 AM   #5
denyo77
denyo77's Avatar
Rate My Car: 198 / 340
Your Ride: 1988 325i Touring
I'm afraid I can't help you here...
you might want to try out a bigger forum like bimmerforums.com, there might be more people who know about the wiring
Unread 03-05-2008, 03:43 PM   #6
320de46m47
yup cheers
How to change your side mirror glass. doughboyea BMW OEM Parts Department DIY's & FAQ's 3 11-07-2010 01:43 PM
525i touring wagon Jay1981 E12, E28, E34, E39, E60 11 07-02-2007 05:13 PM
Poll: Wagon Fixed vs. Flip Liftgate Glass Jeff M. BMW General Discussion 7 10-23-2005 02:04 PM
