Unread 02-24-2008, 01:46 PM   #1
leeella
Your Ride: 325 coupe 2002
Unhappy air bag light
can anyone help have tried to reset my airbag light and it keeps failing to reset.
no fault code are in the system
i am wondering if one off my pre tensioners is knackered but how cam i check this.
Unread 03-15-2008, 09:08 PM   #2
fmbmw
Your Ride: '01 325i
Im assuming you're using an airbag scan/reset tool? With no fault codes there shouldn't be an airbag light on (obviously). However, I had a similar problem while trying to reset my airbag light. I assumed the airbag scan tool worked like my engine scan tool - meaning the ignition needed to be in the ON position. After trying repeatedly to reset my airbag light this way (to no avail) I decided to try with the ignition in the ACC position and presto - worked as advertised, no more light. Hope this helps!
Unread 05-19-2009, 01:11 AM   #3
woodyshop
Your Ride: E36
hello
hello
Unread 06-16-2010, 01:39 PM   #4
leeella
airbag light now reset faulty passenger seat sensor bypass unit fitted and light reset straight away
Unread 07-24-2010, 02:55 PM   #5
totalsilk
Your Ride: p reg e46 1.6
hi my e46 has airbag light on ,if i buy a airbag reset tool will this fix it ? cheers
Air Traffic controllers peterkdenny Comedy Collection
1 11-15-2007 09:25 AM
LIGHTING FAQ and lTUTORIAL habbie Lighting DIY's 0 09-24-2007 12:33 AM
Air Bag Light Problem! PIERRE E46 3 07-11-2007 11:29 AM
Air Traffic Controllers Quotes komodo Comedy Collection
4 10-27-2005 04:47 PM
WTB Side air bag Screw Cover ///Menace328i Bmw Cars For Sale/Wanted 2 06-18-2005 06:04 AM
