Unread 02-17-2008, 09:44 AM   #1
leogomez
Your Ride: 2000 328i
Red face Replace the cable on window regulator.
Hi. New to the forum. I have seen many posts about this, but none that try the following, so I want to document it, in case it actually works.
The cable on the window regulator became loose and tangled around the motor, becoming an unusable mess. I am going to try to remove the terminals, buy steel cable from the hardware store, and actually replace the cable on the regulator.
Wish me luck!
Unread 02-17-2008, 09:59 AM   #2
G'luck, and please let us know how it goes
Unread 02-22-2008, 04:06 PM   #3
mpercella
Your Ride: 2002 bmw 330i
check the end of the cable; if the metal end pulled through the plastic end cap,it may not be as simple as you think...there is a reason the cable came loose. Good Luck!
Unread 02-23-2008, 05:20 AM   #4
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
A better use of time and resources would most likely be to just buy another regulator. They honestly aren't that much and any home-made repair has a high possibility of not functioning correctly and giving you headaches down the line. Or it could work perfectly, you never know.
Unread 02-23-2008, 05:37 PM   #5
wow, where have you been?
Z4 Window Cable Snapped Aid123 Z Series (Z3, Z4, Z8) 5 10-20-2008 05:03 PM
Z4 Window Cable Snapped Aid123 BMW OEM Parts Department DIY's & FAQ's 2 01-02-2008 03:45 PM
Is this the infamous window regulator problem? spicytuna E46 3 11-11-2007 01:34 AM
E46 Annoyances/Fixes Numark318i E46 5 04-27-2007 02:10 PM
WTB driverside window regulator for e36 vegas mikey Bmw Cars For Sale/Wanted 10 11-10-2005 11:50 AM
