Unread 02-11-2008, 02:09 AM   #1
2002E30BaurTC
Your Ride: 1971 2002 and 1987 318i Baur
E30 318i (1987) starting problems
Hello all from Western Australia
New to this forum - haven't even had time to get my details up yet.
I have been having intermittent starting problems.
Turn the key - nothing.
Not a flat battery - lights etc don't dim
If I wait long enough (20 min +), all works fine, perhaps a few weeks, until the next time.
Jiggled auto T-Bar in D and N - no use.
Other possible factors.
Hot weather (90+)?
Air conditioner left on when start is attempted first time.?
Is there a relay that could be failing?
Any ideas appreciated
Unread 02-12-2008, 12:23 AM   #2
HyeTide
HyeTide's Avatar
Your Ride: 1988 325ic 2003 325i
Hi, same thing happened to me, my battery was old and after driving it with a/c on it would not start. After about 30 minutes it would start right up. Tested battery which was weak, replaced it and never had problem again.
Unread 02-12-2008, 01:40 AM   #3
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
Check your ignition switch. If you are getting the lights but no action when you turn to crank on then your switch is not making the connections. You can start by checking that portion by removing the connector from the switch itself adn try to start it like that. If it does the same thing, time for a new switch. Good luck.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Starting problems. asko2807 E36 11 12-04-2007 05:57 AM
1987 325 with Problems! NewBimmer E21, E30 4 11-06-2007 03:45 PM
Dyno Problems with the E30 Turbo jrhaile E21, E30 6 10-27-2005 06:43 PM
E30 318i vs E46 325i Numark318i Kill Stories 4 06-14-2005 11:43 PM
Fellow BMW owner needs Carfax, can anyone help? ilia BMW General Discussion 2 05-05-2005 06:51 AM
