Unread 02-10-2008, 06:23 AM   #1
max79
max79's Avatar
Rate My Car: 197 / 340
Your Ride: E38 1998 740i
BMW flash code
Procedure for Acquiring Flash Codes from your BMW
Instructions by Ben Thongsai, bimmers.com, inc.
Note: Your BMW must have Motronic version 1.1 or higher. Motronic 1.0
cars do not have self diagnostic flash code capability (as evidenced by the
lack of a Check Engine light).
I. Determine which version of the Motronic is in your BMW by
consulting the DME Application Guide (or see table below).
II. Sit in the driver's seat.
III. Turn the igntion to the On position, but do not start the car.
IV. Immediately depress the accelerator fully and release fully 5 times
in quick succession.
V. Wait a couple of seconds.
VI. The Check Engine light will flash once, then start to blink. All codes
are comprised of 4 digits. The number of blinks corresponds to the
fault code. For example, ON, pause, ON ON, pause, ON ON, pause,
ON ON, off would be a 1222.
VII. Each four digit code will be flashed sequentially. When the codes
start to repeat, all stored codes have been displayed.
VIII. Turn the ignition Off.
BMW Diagnostic Flash Codes
DME Version --> M1.x M1.x M3.1 M3.3 M3.3.1
DME Control Unit 1211 2211 1211 1211 1211
Air Mass/Volume Sensor 1215 2215 1215 1215 1215
Throttle Potentiometer 1216 -- 1216 1216 1216
Output Stage, Group #1 -- -- -- 1218 1218
Output Stage, Group #2 -- -- -- 1219 1219
EGO Sensor #1 1221 2221 1221 1221 1221
EGO Sensor #2 -- -- -- 1212 --
Lambda Control #1 1222 2222 1222 1222 1222
Lambda Control #2 -- -- -- 1213 --
Coolant Temp. Sensor 1223 -- 1223 1223 1223
Intake Air Temp. Sensor 1224 -- 1224 1224 1224
Knock Sensor #1 -- -- -- 1225 1225
Knock Sensor #2 -- -- -- 1226 1226
Knock Sensor #3 -- -- -- 1227 --
Knock Sensor #4 -- -- -- 1228 --
Battery Voltage/DME Main Relay 1231 2231 1231 1231 1231
Throttle Idle Switch 1232 2232 -- -- --
Throttle WOT Switch 1233 2233 -- -- --
Speedometer "A" Signal -- -- -- 1234 1234
A/C Compressor cut off -- -- -- 1237 1237
A/C Compressor -- -- -- 1242 1242
Crankshaft Pulse Sensor -- -- -- 1243 1243
Camshaft Sensor -- -- -- 1244 1244
Intervention, AEGS -- -- -- 1245 1245
Ign. Secondary Monitor -- -- -- 1247 1247
Fuel Injectors (group #1) 1251 2251 -- -- --
Fuel Injectors (group #2) 1252 2252 -- -- --
Fuel Injector #1 -- -- 1251 1251 1251
Fuel Injector #2 -- -- 1252 1252 1252
Fuel Injector #3 -- -- 1253 1253 1253
Fuel Injector #4 -- -- 1254 1254 1254
Fuel Injector #5 -- -- 1255 1255 1255
Fuel Injector #6 -- -- 1256 1256 1256
Fuel Injector #7 -- -- -- 1257 --
Fuel Injector #8 -- -- -- 1258 --
Fuel Pump Relay Control 1261 2261 1261 1261 1261
Idle Speed Actuator 1262 -- 1262 1262 1262
Purge Valve 1263 2263 1263 1263 1263
EGO Heater 1264 2264 1264 1264 1264
Fault Lamp (check engine) -- -- -- 1265 1265
VANOS -- -- -- -- 1266
Air Pump Relay Control -- -- -- 1267 1267
Ignition Coil, #1 -- -- -- 1271 1271
Ignition Coil, #2 -- -- -- 1272 1272
Ignition Coil, #3 -- -- -- 1273 1273
Ignition Coil, #4 -- -- -- 1274 1274
Ignition Coil, #5 -- -- -- 1275 1275
Ignition Coil, #6 -- -- -- 1276 1276
Ignition Coil, #7 -- -- -- 1277 --
Ignition Coil, #8 -- -- -- 1278 --
Control Unit Memory Supply -- -- -- 1281 1281
Fault (code) Memory -- -- -- 1282 1282
Fuel Injector Output Stage, no cyl # -- -- 1283 1283 1283
Knock Control Test Pulse -- -- -- 1286 1286
No Failure 1444 2444 1444 1444 1444
740i
Unread 02-10-2008, 10:39 AM   #2
pswirley
Rate My Car: 222 / 340
Your Ride: 93 325i
Good information. this should be stickied, I have used it and it seems to come up a lot.
Unread 02-10-2008, 11:44 AM   #3
max79
max79's Avatar
thank u guys
really interested info
740i
Unread 03-10-2008, 05:01 PM   #4
Dave Baker
Your Ride: 1994 BMW 325 IC
My code flashes 1221 "EGO Sensor #1...the car runs excellent as normal...Is it urgent to repair this right away? What's the typical cause, defective oxygen sensor, power relay or fuel mixture/combustion problem? Cost of repair?
Unread 03-26-2008, 12:44 PM   #5
gcerdas
Your Ride: 1992 325is
update
i guess i have alot to learn
i would like to get my 325is to look at least a decent look
i broke the front bumper and bent the M3 DS1 WHEEL .
i have looked all over and cant find the parts
i am new to this but i know i have to fix my ride
GC
Unread 02-06-2009, 02:41 PM   #6
Smittythefe
Your Ride: 94 325i Convertible
thanx
Unread 03-16-2009, 08:14 PM   #7
89stinger
Your Ride: 97 328i
Nice ... it works! Thanks
Unread 05-10-2009, 03:45 AM   #8
yanivgol
Your Ride: 1998 e36 318i sedan
cheak the oxigen sensor
Unread 05-10-2009, 03:47 AM   #9
yanivgol
cancel the right side air bag
hi i got new baby last week and i would like to know
if i can cancel the right side air bag on my bmw e36 1998 auto 4 d sedan?
mybe there is fuse or sensor that i can take out just for now untill i can put him on the back seat.
thanks !!!!
Unread 10-18-2009, 06:35 PM   #10
ozzieman
Your Ride: 1991 318is/1988 l6
hey I tried this in my m3 and the check engine light just stayed on?
Unread 01-28-2010, 04:13 AM   #11
karimMsalama
Your Ride: BMW M5 VW MK2
thanks for the info
Unread 06-02-2010, 09:45 AM   #12
DSP543GP
Your Ride: 1993 320i
Hi Guys!!!
Can someone tell me if this works on the 1993 320i models and which "ON" position are you refering to? There's "On" which unlocks the steering wheel and on that allows to turn "ON" anything? So which one is it. Thanks!!!
BMW e36 320i
E46 Light Alloy Wheels
Everything standard and original
Unread 09-01-2011, 10:09 AM   #13
amirboom
Your Ride: bmw 320i e 36 1998
hi every one
i have bmw e36 320i 1998
i have done a huge mistake,i wanted to replace the old battery with the new one an unfortunately i reversed the pole of battery and after a min there was a mass of smoke coming out of my car.
i took it to the show room and they told me the alternator and the main electrical system is gone and i have to pay about 1500 EUR to change the mane electrical part,
do u guys know what is the main electrical part or is there such a thing in a car
couse after that accident the car was starting all the light and every thing was working but the car didn't turn on.
please help and give me some advise
Unread 12-28-2011, 02:53 AM   #14
nhevynopal
nhevynopal's Avatar
Your Ride: 93 318is
hey amirboom their are a couple of things that can go wrong first well i am not shure if the cable that does from the battery to the power distribution box has a fusable link. if it does not that's going to need a new one and then for the rest it does have them. u need to get ur hands on a wiring diagram and locate the fusable links but first see if there r some in the cable that goes from the battery to distribution box mmm 1500 euros is 2000 dollars almost r u planning on doing this ur self because other wise u pretty much r going to have to trust them on that one it sound like a right price see if they r going to replace ur battery for that price because you are going to need a new one hope dis helps
Unread 03-10-2012, 09:42 PM   #15
gc325is
Your Ride: 325 1995
How do you erase the flash code once fixed?
Passenger SRS air bag cannot be turned off but the sensor can be fooled. Check ebay for a SRS simulator if not the fault light will illuminate and need a air bag tool to reset.
BMW Drives into the Fall TV Season komodo BMW General Discussion 3 10-28-2005 01:05 AM
BMW Worldwide Sales Rise by 11.4% in September komodo BMW General Discussion 0 10-26-2005 01:11 PM
