Unread 02-02-2008, 10:11 PM   #1
GC540i
Your Ride: 2000 e39 540i
Exclamation 540i exhaust
Can anybody tell me if removing the resonater off my e39 540i would cause any problems?
Unread 02-02-2008, 10:22 PM   #2
craig
craig's Avatar
Title: Sitting in Time out
Send a message via MSN to craig
nope. shouldnt cause any problems, people remove it all the time with no reported problems.
Unread 02-05-2008, 09:15 PM   #3
dinan540
dinan540's Avatar
I haven't done it yet. But it will save you weight and give your car more a mean exhaust note.
540i with some mods
Unread 06-03-2009, 09:47 AM   #4
FJD
Your Ride: 1999 BMW 540i (e39)
Send a message via MSN to FJD Send a message via Skype™ to FJD
I heard a rumor that if you remove the resonators that you will loose some torque because you have less back pressure.Is this true ?
Unread 06-04-2009, 03:02 PM   #5
Maybe, generally as long as you remove something AFTER the cat and O2 sensors you don't really affect anything that the car can't compensate for. If you're worried though get a replacement like a flowmaster, not the greatest performance muffler ever made but it maintains the back pressure needed and gives you a GREAT exhaust note.
Unread 06-10-2009, 02:27 PM   #6
devinwwu
Rate My Car: 49 / 340
hack off the rear can right where it splits into the two chambers. One of them is closed and is designed to smooth out exhaust resonations, and the other is just the rear muffler with a turn down exit.
I cut it at the joint and angled my cut so the exhaust went towards the rear of the car. Without the muffler there it sounds great. The thing has to weigh at least 40 lbs and the car is not too loud at all without it. It is how the 540 should have sounded from the factory. very calm at idle and cruising, and a low muscle note through the lower rpms.
best part... $0 if you have your own sawzall... (Which I do)
Unread 06-10-2009, 10:32 PM   #7
That trick also works on the inline 6 cyl's as well. Mellow throaty note at idle, still smooth and relatively quiet at cruise but when you stick your foot in it.....hell yeah. Not sure how they do it in S.A. but if your in an emission control zone in the U.S. you'd better have a replacement when it comes to inspection time. Otherwise....play ball
Unread 02-08-2012, 07:00 PM   #8
Robnayl
Your Ride: 1999 540i m sport
I've got a 99 540i 6 speed. I cut the muffler off and added a piece of tail pipe to route it as stock. Very nice mellow gowl until about 3k then sounds as a European V-8 should. The bonus is a much stronger top end. Do not remove the resonator as it will be much louder and pop and backfire when decelerating. Total job cost was 70 USD for a muffler shop to add the tail piece.
Noisy Exhaust Maxi E36 8 01-30-2008 02:37 AM
Rogue Engineering Ikon exhaust Rooz Video and other Multimedia 1 01-24-2007 04:25 PM
I Pulled the trigger + Vid! Rooz E46 13 01-23-2007 05:32 PM
For Sale: Active Autowerke Gen. III Exhaust E46 M3 His ///M-inence Bmw Cars For Sale/Wanted 1 12-21-2006 05:05 PM
So me and Komodo were testing out his exhaust ChrisWorrell Kill Stories 10 07-14-2005 12:04 AM
