Lighting
Sponsored by: BavToys.com
Unread 01-31-2008, 11:29 PM   #1
fgmx
Your Ride: 1993 BMW 325is
325 brake light problem
1993 325is Electrical help
I recently purchased a 1993 325 is, my first BMW.
I got the engine compartment wet.
I now do not have rear brake lights. I checked the #46 fuse and it is fine.
I have not checked the brake pedal switch and the grounding on the circuit , that is my next step
I have a MID display code saying check brake circuit.
Can anyone provide clues ?
I do not have an owners manual ?
Does anyone know where I can obtain an online owners manual and a
troubleshooting guide for the MID codes ?
I noticed someone else had the same problem . Did the grounding or the switch take care of the other person's problem ??
Anyone experience this problem before and can offer advice on what it could be?
Could the brake fliud level sensor getting damp cause such an error code ?
Any help in solving this problem is greatly appreciated .
Unread 02-01-2008, 02:09 PM   #2
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 255 / 340
Your Ride: 1997 328i
In my Bently manual, under electrical component location it says: fuse 46 15a-Brake lights, Multifunction clock (see also fuses 23,27,31,45).
You should check if you have power at brake LIGHTS using a 12v test light, then check for power at the brake pedal switch, also check those other fuses. What the heck check all the fuses!!! Using your 12volt test light!!!!
Unread 02-01-2008, 02:52 PM   #3
fgmx
Hello :
The fuse # 46 is good. I have voltage at the light grid/panels at the rear of the car. I also show power at the switch connection plug.
I have the switch out. It is a 4 conductor plug . How does oe ne check the plug and the ground ?
If I need to run a new ground how and where do I do that ?
Brake Light Circuits cruzn4abruzn E36 6 12-08-2014 09:01 AM
Brake light circuit problem BBizzle4888 E12, E28, E34, E39, E60 9 12-08-2014 08:47 AM
Radio & Warning Light Problem larsonc E21, E30 6 11-20-2006 09:35 PM
fog light problem HELP! Tochenzo Lighting 6 10-10-2006 11:32 PM
