Unread 01-25-2008, 05:31 PM   #1
sektornj
Your Ride: 95 318i
95 318i 1222 code- CEL- Help?!
Im somewhat new to the BMW world, but I am a pretty avid wrench- so here's my dilema..
I have a 95 318i w/m42. About a month ago she started running like crap, poor fuel economy, check engine light coming on, and hesitation. She has about 120k on her. I stared by replacing fuel filter, coil, wires, & plugs which helped a little. CEL still coming on. Pulled the code 1221- so I replaced the O2 sensor. Helped a little bit more, but now i still get a CEL and hesitation- now pulling code 1222. I got the bently book and checked everything from airbox to intake and vac lines and cant find anything. MAF is clean, idle is fine, but hesitates when passing or getting up to speed.
Has anyone else run into this head-scratcher?
Any help would be much appreciated!
Thanks!
Unread 01-25-2008, 05:37 PM   #2
Have you tried a water remover for the fuel?
Unread 01-25-2008, 06:32 PM   #3
sektornj
Your Ride: 95 318i
I havent tried that, but i guess i will. I dont really think thats the problem but at this point ill try anything.
Thanks!
Unread 01-26-2008, 08:47 AM   #4
max79
max79's Avatar
Rate My Car: 197 / 340
Your Ride: E38 1998 740i
Check the motoronic ? Maybe it has water damage open it and take a look inside?
Have you try to clean the injectors?
did u check the fuel pump coz as u told at idle its fine so maybe the fuel pump have problem, its filter maybe dirty ??
what do u mean by that , plz can u tell me how to do that????
740i
Unread 01-26-2008, 08:59 AM   #5
max79
max79's Avatar
740i
Unread 01-26-2008, 10:56 AM   #6
There are fuel additives with alcohol which would absorb any water in the fuel.
Unread 01-26-2008, 11:17 AM   #7
max79
max79's Avatar
one more question how water goes into the fuel? and thanks for the info.
740i
Unread 01-26-2008, 11:34 AM   #8
Most often, water gets into the fuel by condensing on the sides and exposed surfaces of the tank out of simple humidity in the air during times when it's near empty. Keeping the tank near full most of the time should be enough to prevent that.
Unread 01-26-2008, 01:46 PM   #9
max79
max79's Avatar
IC , thank u for this useful info.
740i
CEL Fault Code FC - Incorrect Purge Flow kvadgama E36 3 12-06-2006 10:01 AM
fault code 1222 jybute E12, E28, E34, E39, E60 2 03-06-2006 09:11 PM
Ran my code reader this morning before my appointment - 3 new codes billycuth E36 8 06-28-2005 07:41 PM
