Unread 01-15-2008, 01:09 PM   #1
APE36
APE36's Avatar
Your Ride: 1994 BMW 325i
E36 Climate Control Removal
Hello, I am having an issue with my climate control unit (this is the unit with the dials, NOT the digital unit ). I wanna remove it and take a look at it. I followed other directions online, and they say to pop out the onboard computer, then stick your finger behind the climate control unit and push it out. I tried this, but the climate control unit won't budge at all. Am I doing something wrong? can someone tell me how to properly remove the unit?? Thanks!
///ANTHONY
Unread 01-16-2008, 04:39 PM   #2
cocktane
Your Ride: 93 e36 325i
Im having the same exact problem.
However, I have also unscrewed the two screws behind the two big dials.
But, I still cant get the ac out, becuase its to wide push out from its hole.
Anyone know how to remove it??
Unread 01-16-2008, 07:26 PM   #3
cocktane
Ok, I found out... red the service manual.... u first have to unscrew the two screws behind the big knobs.... then, remove front panel on the a/c.... and then push the a/c unit back, and down.. and slide it out the MID slot... should work
Unread 01-16-2008, 08:23 PM   #4
APE36
APE36's Avatar
Oh good! thank you so much! I will try that as soon as possible and let you know how it goes.
///ANTHONY
Unread 01-16-2008, 08:26 PM   #5
Yeah, that's how you do it. He beat me to it. The finger trick is for the OBC display thing.
Unread 01-17-2008, 12:57 PM   #6
APE36
APE36's Avatar
wait........ the MID slot you mentioned is the obc port right??
///ANTHONY
Unread 01-17-2008, 01:12 PM   #7
APE36
APE36's Avatar
Also, would I be able to easily replace my analog dial unit with the newer digital unit??
///ANTHONY
Unread 11-15-2010, 10:44 AM   #8
stan
Your Ride: 97 740il 95 325is
Hi guys, I'm having the same problem with my 95 325is. I know its been a while but do you remember how it came out, did you have to disconnect the wire harness first or anything special? Mine keeps getting stuck, it doesn't want to go down, I've tried back and front first. Any help would be appreciated. Stan
Repairing climate control unit SHAHAB323IS BMW OEM Parts Department DIY's & FAQ's 16 08-18-2010 05:22 PM
PLEASE HELP serious climate control issues 1994 325is!!!!!!!! kevinl34 E36 2 05-10-2007 01:55 PM
325is climate control problems!!!!! kevinl34 E36 4 05-03-2007 04:01 PM
Fix your analog climate control backlight Dudesky BMW OEM Parts Department DIY's & FAQ's 1 11-06-2005 09:01 PM
