Unread 01-14-2008, 03:38 PM   #1
peterkdenny
peterkdenny's Avatar
Your Ride: '96 328is
328is problem, runs weird - Vacuum hose leak? something clogged?
I just bought a '96 328is (i just hit a deer with my 325 and totaled it) and it doesnt run quite right. Every once in a while it will sputter out at about 800 rpm when its in gear with the clutch in or even just idleing. It sounds like something is clogged almost when this happens. Also, when i get up to speed and maintain a constant speed with steady throttle, the comes in and out in two second intervals. With the throttle perfectly still, i can see the mpg gauge dip up and down when this happens. Could it be some sort of vacuum hose problem or something thats clogged? The car accelerates fine when i stomp it. I would appreciate any help or ideas.
Also, my abs and my brake pad lights are on. My brake pads are fine and the rotors are new, does anyone know why they are on?
Also pictures coming soon of the new car and the wrecked one.
Unread 01-14-2008, 04:22 PM   #2
gldfshkpr
gldfshkpr's Avatar
Your Ride: '97 318i M44 - Sedan
From what I understand there are brake pad sensors that need to be replaced along with the pads. I'm sure someone here can elaborate on that more. The ABS light means something is not right with the system and you have conventional brakes now instead of anti-lock. That's what the owner's manual says anyhow. Sorry to hear about your 325 and congrats on the new car.
Peace,
Kirk
Hang up and drive.
Unread 01-14-2008, 04:39 PM   #3
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 123 / 340
Your Ride: '97 328i
like he said when the pad light comes on it doesnt just turn off with new pads, the sensors have to be replaced. (not expensive and easily replaced) for the abs light i would check the simple stuff first like the wheel speed sensors.
Unread 01-15-2008, 08:46 AM   #4
Yes, brake pad sensors, or more likely just the wheel speed sensors, they might just need to have the contacts cleaned; if that doesn't do it, then I don't think replacement is that big a job.
As to the running, you might have to go through all the fundamentals, air filter, plugs, 02 sensor, idle control valve, fuel filter, especially if adequate maintenance records didn't come with the car.
Unread 02-16-2008, 11:27 PM   #5
peterkdenny
oh yea, i got the running problem fixed a while ago, i had a huge vacuum hose leak in the intake. In was some valve with three letters before the valve, but i forget what it was... something like pcf valve but if anyone else has something similar, thats it
Need help with a fuel hose leak Douglas E21, E30 6 04-26-2007 05:26 PM
