Lighting
Sponsored by: BavToys.com
Unread 01-13-2008, 04:40 AM   #1
Maxi
Maxi's Avatar
Your Ride: BMW E46 328i 99
Questions about my 325i US lighting
I dont know if what I have in my 325i 93 lighting is an orginal or made by the last owner.
1st. thing : The front signal lights is working as standard lights when I turn On the lights,while the INTERMEDIATE lights ( the small lamps of the headlight )not working!!!.
2nd. thing : When I turn On the High beam lights, the fog lights automaticly cut off!!!
I'm waiting for your opinions.
Maximum Power
Unread 01-13-2008, 10:10 AM   #2
If you mean the turn signals light on lower power than while signaling with the lights on, that would be normal for US spec. If you mean the intermediate light in the headlight is a low power light in the headlight with low beams (dip beam) off, there is none in US spec, the low power signal takes the place of that. Fog lights cutting off with bright or main beams is normal US spec.
Unread 01-13-2008, 10:21 AM   #3
Maxi
Maxi's Avatar
So, Do you mean that every thing my car lighting is normal.
But,,, how about the fog lights, Are you sure that's normal. When I try to do flashing by the bright beam, the fog lights turn off. And when I turn the bright beam off, the fog lights come on again!!!. Is'nt seems like a stupid thing. Why did they make it like that?
Please Be sure that's normal, and tell me.
I cant bileave this. I havent see any american car do somthing like this before.
Thanks,
Maximum Power
Unread 01-13-2008, 11:14 AM   #4
Thanks,
Yes, it all seems totally normal. The idea is that the fog lights are redundant because they are unnecessary if you are able to switch to bright beams. This same relay is unavoidably used when using the bright beam flash. My E30 lights do all these things exactly as you described.
Unread 01-13-2008, 12:48 PM   #5
Maxi
Maxi's Avatar
mmmmm.. thanks mate.
Is there a way to convert the lighting sys. to be like euro sys.??
Maximum Power
Unread 01-13-2008, 02:08 PM   #6
A lot of rewiring...
Unread 01-13-2008, 02:36 PM   #7
denyo77
denyo77's Avatar
Rate My Car: 198 / 340
Your Ride: 1988 325i Touring
I'd actually love to have the low light turn signals... I think it looks good
I found an instruction on how to do it on a German website, so I guess I'll do that in the next couple weeks
it's actually no big deal, they say it takes you bout 30 minutes
Unread 01-13-2008, 03:15 PM   #8
you can get euro headlights which are much better for a start
Unread 01-15-2008, 03:44 AM   #9
Maxi
Maxi's Avatar
I'll get euro headlight later for my car. but I'm thinking to change the sys of the fog lights.I dont want it cut off when I turn On the bright beam.
Is it possible to do it. is it a big project.
Please help me.
Maximum Power
Unread 01-15-2008, 07:57 AM   #10
Why does it really matter? How often are you driving with your hi beams on?
Unread 01-15-2008, 03:28 PM   #11
denyo77
denyo77's Avatar
well I would want my fogs to be on along with the hi-beams as well
and I have that feature
Unread 01-15-2008, 05:33 PM   #12
The relay that turns them off may be by passed or removed.
Unread 01-16-2008, 02:28 AM   #13
Maxi
Maxi's Avatar
Aha... Could you show or tell me the relay location.
Thanks,
Maximum Power
06 325i, more questions? davidbise E90 2 11-01-2007 07:16 PM
LIGHTING FAQ and lTUTORIAL habbie Lighting DIY's 0 09-24-2007 12:33 AM
Turbo for 325I? maximk2 E36 9 04-28-2007 09:17 PM
Lighting Questions for '94 E36 BlkMagiks Lighting 1 06-04-2006 09:42 PM
Bulb Replacement/ and other questions. ///Menace328i E36 0 05-13-2005 10:07 AM
