Unread 01-12-2008, 09:23 AM   #1
bebiloku
Your Ride: bmw 1993
Bmw 520i Crack And Misfire.
I Stop My Car For Some Hour For Example I Close In The Postprandial And I Start In The Mornig The Car Run Very Vell For 3or 5 Km After The Car Misfire And Crack To Exhaust .for This Problem I Have Test And Change New Spark Plug (beru Ultra X Platin),change Fuel Filter ,change Air Flow Sensor ,fuel Pump .what To Do ,i Go Crazy
Unread 01-12-2008, 10:48 AM   #2
Unburned fuel into the exhaust? Maybe an ignition wire is bad.
Unread 01-13-2008, 03:14 AM   #3
bebiloku
Your Ride: bmw 1993
YES FUEL INTO THE EXHAUST,PLS HOW TO TEST WIRE.
Unread 01-13-2008, 10:02 AM   #4
If you can use a multimeter, each wire can be tested for conductivity using the resistance settings.
Unread 01-14-2008, 02:25 AM   #5
bebiloku
Your Ride: bmw 1993
YES I CAN USE IT ,I WORK WITH GSM MOBILE REPAIR.THANK YOU
Unread 01-14-2008, 02:28 AM   #6
bebiloku
Your Ride: bmw 1993
Is Posible Not Sufficent Fuel From Fuel Pump To Make Crack And Misfire?
Unread 01-14-2008, 11:12 AM   #7
I would not think so, since fuel must be getting into the exhaust.
Unread 01-24-2008, 05:48 AM   #8
bebiloku
Your Ride: bmw 1993
YES TRUE MY PUMP WORK WELL NOW I DOUBT TO MY CATALITIC MAY IT IS BLOCKED ,I AM WAITING NOW MY FREND FROM USA TO COME IN MY COANTRY ALBANIA TO REMUVE THE EXHAUST AND TO TEST THE CAR OLSO I MAKE ORDER THE CARSOFT 6.5.
Unread 01-24-2008, 07:51 AM   #9
macky55e34lover
macky55e34lover's Avatar
Your Ride: BMW '94 E-34 525i
Have the wires checked, including the sparkplugs, sometimes other branded-sparkplugs are not matched with the engine. Try to look at the fuel lines also.
Unread 01-25-2008, 07:39 AM   #10
bebiloku
Your Ride: bmw 1993
the spark plugs are new (beru ultrax platin) findet in beru site,yes i test all wire with multimter ,fuel line i think are ok bexouse if the baxkfire come from low fuel there is not backfire to exhaust but to manifold .my opinion now for my car is or catalitic blocked or all coil need to replace with new.i dont know ,may be
Unread 02-03-2008, 07:06 AM   #11
bebiloku
Your Ride: bmw 1993
Thank You For Help ,i Change The 6 Coil And My Car Is Ok Now .
