Unread 05-26-2005, 02:37 PM   #1
projal147
Send a message via AIM to projal147
Help removing A/C belt
I have narrowed the noise coming from my car to the belt that runs the A/C. I looked up how to replace the belt and I need to loosen the pulley which keeps the belt tight as the fan runs the belt, etc. But my problem is that after an hour and a half of trying to loosen the bolt which keeps the pulley pressed against the belt. does anyone know how to loosen the pulley or change the belt without loosening the pulley? I've sprayed the bolt with wd-40 and metal loosener, but nothing has worked.
help?!?!?!?
Member of "Ran From A Cop And Got Away" Club
My goal is to race in the Gumball 3000 by the age of 28.
New York Yankees - It's A New Year.
Unread 05-26-2005, 02:52 PM   #2
lol, I just did this when I changed pulleys, so am probably in the best position to give you an answer to this. Ok, when you look at you AC pulley, their should be a small pulley close to it (between your crank and your ac pulley) That's your tensioner, it looks like a little shock, it has 3 bolts the one in the middle has a cover. The top bolt (I think a 10 mm or 13 mm could even be 16mm) is what you will need to do, get your self a wrench and use some elbow grease on it and tighten it so that the all thing should come down, and that's when you take the ac belt off.
Unread 05-26-2005, 04:00 PM   #3
projal147
yea it is a 13mm bolt. so i have to tighten the bolt? to get the belt off?
Need a little A/C help E36Bimmer E36 11 06-18-2006 02:44 PM
BMW Belt I will make Spieluhr United Off Topic  **FOR MEMBERS ONLY** 25 09-21-2005 04:08 AM
a/c system B3M2W5i E36 12 08-10-2005 09:31 AM
A/C question- real quick E36Bimmer E36 7 08-05-2005 07:32 AM
Fan Belt Joey E21, E30 7 04-18-2005 06:38 PM
