Unread 12-08-2007, 07:10 PM   #1
f1indycar
f1indycar's Avatar
Rate My Car: 183 / 340
Power steering problems
Have had a leak in the power steering. Local shop has replaced many clamps on the hose, but it still leaks. They say if it keeps leaking, they will order a new power steering hose. Anyone have any idea what the problem might be? Or are they even on the right track? Any help would be great. By the way it is a local garage not a BMW service. (No warranty) keeping it cheap! Car is a 2001 330i.
Unread 12-08-2007, 10:04 PM   #2
Antiburn
Antiburn's Avatar
Rate My Car: 193 / 340
e46's always have leaking p/s hoses. Its usually the hose from the resv-cooler and from resv-pump. Fairly easy job to do, just dont forget to bleed the system afterwards or you will get hard steering. It takes regular ATF fluid.
Unread 12-08-2007, 10:08 PM   #3
yea replace the hose if its leaking. Itll get messy otherwise.
Dextron 3 ATF or better.
Unread 12-09-2007, 11:14 PM   #4
TECH
Your Ride: Sick cars.
It's usually the two hoses that Antiburn mentioned. There is one pressure hose (no clamps used) that could be leaking, and since it's under pressure, could lose fluid quickly. Also, the steering rack could leak, which would put fluid into the boots of the rack.
E38 Power Steering TwinCam 7 Series (E23, E32, E38, E65, E66) 7 03-04-2008 05:34 PM
Changed My Power Steering Fluid Numark318i BMW OEM Parts Department DIY's & FAQ's 2 11-01-2007 01:59 AM
Power Steering Fluid Showing on the VDO Jimmie34 E12, E28, E34, E39, E60 4 05-09-2007 09:15 AM
Power Steering Loss-help!!! tonyvt328is Tire, Wheels And Suspension Forum 2 01-31-2007 09:33 AM
Power steering. catalyst E36 4 07-26-2005 12:04 AM
