Unread 12-04-2007, 12:14 AM   #1
digismack
Your Ride: 1997 BMW 318i
Brake Lights - Please Help
None of my rear lights are working.. none. I replaced the brake light switch down by the brake pedal tonight and they still don't work. I replaced the fuse for the brake lights and.. they still don't work. None of them. I turn my car on at night and look in the back and I have no lights on.. none. What could this possibly be? Any help is greatly appreciated.
Oh, and.. my headlights have been acting up as well. My mechanic "rigged" the lights to work until he "gets the new switch in".. but the more work I do myself to the car, the less I start to trust the mechanic.
Unread 12-04-2007, 12:17 AM   #2
How is the fuse box? Got a multimeter? If so, you can check for voltage at the light sockets
Unread 12-04-2007, 12:22 AM   #3
digismack
I replaced the fuse (#46, I believe) with a fresh fuse from NAPA. No go. I don't have a multimeter though.. I've been reading around and I hear it could be a ground problem. Where would I look for the ground connection to see if it's bad?
Unread 12-04-2007, 12:32 AM   #4
If the multimeter reads + 11 or more at the light sockets with a local ground, then a ground issue is the problem.
Unread 12-04-2007, 12:34 AM   #5
digismack
I don't have a multimeter to test this right now.. for now I can at least check to see if it came loose. Problem is, I don't know where the ground wire would be for this.. any help?
Unread 12-04-2007, 12:39 AM   #6
digismack
Also, possibly of interest for diagnosis... my license plate holder lights work.. but nothing else on the back.
Unread 12-04-2007, 05:52 AM   #7
Do you mean to say that you don't have a headlight switch? Most of the wiring for the exterior lighting runs through this switch, so if it's bad, then that's your culprit.
Unread 12-04-2007, 12:33 PM   #8
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 255 / 340
Your Ride: 1997 328i
+1
Unread 12-04-2007, 08:52 PM   #9
digismack
Yep, I do believe my headlight switch is bad.. that would effect my brake lights / rear lights as well? Thanks!
DIY: E39/E36 Brake Pad Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 11 12-20-2014 07:21 AM
Brake lights rewired- opinions please Dudesky E36 3 05-27-2006 09:16 PM
