Lighting
Sponsored by: BavToys.com
Unread 12-02-2007, 09:56 AM   #1
davidrc
Your Ride: 318i 1998
Angry Urgent - NO break lights !
Hi all,
Listen to this: A few days ago all my break lights went dead. All three (two tail lights and the one at the back window).
E36 ; 318i ; 1998
I have checked the fuse - OK
I have checked voltage on the two tail break lights (while someone press the break peddle) - ~ 11.3V
Replaced all 3 bulbs
NO BREAK LIGHT!!!
Any idea??
It's urgent!
Unread 12-02-2007, 11:56 AM   #2
HyeTide
HyeTide's Avatar
Your Ride: 1988 325ic 2003 325i
Have you checked brake light switch at the brake pedal?
Unread 12-02-2007, 01:14 PM   #3
davidrc
Since I have verified that there is voltage on the bulb socket when the break peddle is being pressed, and since I can take the gear knob out of its parking position when the break peddle is pressed, I would think that the switch is ok.
The previous owner of my bimmer, took the negative pole for the break lights from the car body (and bypassed the original). Maybe its a ground problem?
Unread 12-02-2007, 01:17 PM   #4
on our volvo the brake light switch and the brake pedal sensor(to take it out of gear) were two seperate devices. I think to take it out of gear theres a vacuum switch of some sort.
so its prolly the brake light switch at the pedal
Unread 12-02-2007, 01:36 PM   #5
davidrc
It can NOT be the switch, since as I said, when the break pedal is pressed, there is a ~11v on the bulb socket. Even though, it does not lit (and I have placed 3 new bulbs.
In addition, on the 318i, '98, when you disconnect the wire from the switch, you can not take the shift knob out of parking so I guess the switch is used for both operations (break lights and parking release)
Unread 12-02-2007, 01:40 PM   #6
Mila318is
Rate My Car: 265 / 340
Your Ride: 1994 e36 318is
The brake light switch tells when the peddle is being pressed that's what make's light's come on and go off, i've just had mine replaced as the brake lights were staying on constantly.
I'd say it was the same on your's but the other way round, if that makes sense.
Unread 12-02-2007, 01:50 PM   #7
I think that's exactly right.
Unread 12-02-2007, 01:56 PM   #8
nice job sir
Unread 12-02-2007, 02:02 PM   #9
davidrc
Guys listen,
When a good working switch is being pressed, it transfers electricity (=voltage, current....).
I'm telling you that when the break peddle is being pressed, I DO HAVE CURRENT AND a voltage reading in the break bulb socket ===== the switch works!!
I don't know, maybe it's a grounding problem, or something else, but it can not be the switch (though everybody loves this easy and straight forward solution)
Unread 12-02-2007, 02:05 PM   #10
Guys listen,
lol
what are we talking about again..shit?
k seriously..ground it somewhere else?
also are you sure you need that much voltage at the socket? You might need more, which is why the bulb is lighting up?
Make sure the fuse is of the correct voltage?
If not check the line for any cracks or breaks? If it not fully grounded out it may only transfer some of the voltage?
Unread 12-02-2007, 02:34 PM   #11
That's why I think it is a bad ground
Unread 12-02-2007, 04:00 PM   #12
NO
you know its the muffler bearing. you just dont want people to know about the adverse effects of a bad muffler bearing.
Unread 12-02-2007, 07:27 PM   #13
Guys listen,
Okay, first of all it's PEDAL not peddle. Secondly, it's BRAKE, not break. Thirdly, what does your OBC tell you? Does it say "BRAKE LIGHT CIRCUIT", or does it say "BRAKE LIGHT FAILURE"?
Unread 12-02-2007, 07:48 PM   #14
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 255 / 340
Your Ride: 1997 328i
Well you have about 12 volts of positive current at your source, the brake light assembly! What you don't have is a ground!!!! Because when you checked with your voltmeter you had current because you made your own ground!!! Find the ground wire, that's your problem!!!!
Unread 12-02-2007, 08:30 PM   #15
dam....we are all so pissed. lets take it down a notch or two.
E30 parking break switch Littlebimmer Car Audio and Electronics 6 03-14-2007 11:26 PM
