Unread 11-16-2007, 10:49 PM   #1
Exilion
Exilion's Avatar
Your Ride: 1991 325i
Aftermarket brakes / brake caliper
Alright I am considering replacing the brakes with something new next time it craps out. Now since the e30's brake calipers have been known to become stuck I was wondering if it was a good idea to replace them with an after market part. Any thoughts about safety, tools needed for installation, and what would you recommend using.
Unread 11-17-2007, 11:16 AM   #2
I would think to just buy some rebuilt calipers, you will need to replace both at the same time (Per axle). If you want something more performance oriented there is a small company that offers a 300mm disc with a 2 piston willwood caliper but they cost a pretty penny and won't fit under your bcaps. My best suggestion is just buying some rebuilt ones, I think i have gotten a couple from pelican parts. Then maybe use the old ones as an exercise in rebuilding calipers.
Unread 11-17-2007, 02:11 PM   #3
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 131 / 340
^^^ yeah, i have heard that fitting any other brakes on an e30 is a nightmare, especially with the bottlecaps like nick said. that being said, the E30 has pretty decent braking as it is. i plan to continue using good pads, and then just getting some stainless steel brake lines to firm up pedal feel.
Unread 11-18-2007, 05:22 PM   #4
Exilion
Exilion's Avatar
ok thanks guys
DIY: E30 Front Wheel Bearing Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 14 12-20-2014 07:22 AM
E30 Brake Caliper problem..check yours. Numark318i E21, E30 6 11-10-2011 10:53 AM
Must I bleed the brakes? drz E36 7 07-11-2006 11:50 AM
