Unread 11-07-2007, 05:01 PM   #1
dev6315
dev6315's Avatar
Your Ride: 1989 325is
E30 325is ABS light is on
I just bought a really nice 1989 325is. When I bought the car the ABS and Brake lining light was on. The previous owner said he just replaced the rotors and pads. I already bought the front left and rear brake lining sensors. How many ABS sensors does this car have? I am waiting until I have everything I need before digging in to fix both probs. Also, is there a good source for new or used ABS speed sensors? Thanks in advance.
Unread 11-07-2007, 05:49 PM   #2
Exilion
Exilion's Avatar
Your Ride: 1991 325i
As far as I know there is one sensor per wheel. Cause I'm lazy I'll just copy from the bentley manual
If the ABS warning indicator comes on a visual inspection of the system may help to locate the fault. Carefully inspect the wiring harness. Check especially the harness and connections near each wheel for chafing or damage due to incorrectly routed wires. If the wheel sensor harness is damaged, the wheel sensor with its integral harness should be replaced
The pulse wheels themselves may be responsible for faulty speed signals reaching the control unit. Inspect the pulse wheels for damage such as cracks or missing teeth. Check to see that a crack has not made the pulse wheel loose. Spin the tire to check to see if the pulse wheel is out-of-round. Check for dirt or worn wheel bearings which could reduce the clearance between the sensor and the wheel. Even accumulated metallic brake pad dust has been known to cause problems. A faulty pulse wheel should be replaced
Unread 11-07-2007, 06:42 PM   #3
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 131 / 340
this happened to my first E30. i fixed it by taking out the light bulb to the dummy light.
id prefer to not have abs, and thats what that light is just saying that your brakes wont "pump", but they will still apply fine.
Unread 11-07-2007, 06:49 PM   #4
Exilion
Exilion's Avatar
that's so much simpler (and cheaper)
Unread 11-07-2007, 07:46 PM   #5
It may come on if the brake fluid needs changing. But I don't think it would be on all the time.
Unread 11-07-2007, 07:58 PM   #6
dev6315
dev6315's Avatar
Thanks for all the replies. I will most likely just disable the idiot light right now. I checked and all the wiring is in good shape, so I dont know. I might replace them down the road when I upgrade to drilled and slotted rotors. Thanks again for all the help!!
Unread 11-07-2007, 08:10 PM   #7
dev6315
dev6315's Avatar
Also, where do you guys get a lot of your parts. I know the main places (this is my 3rd E30), but didnt know you knew of some other sites. Ebay is huge and BAVAUTO, but they are getting tough to find. Thanks in advance!
1989 325is ///
Unread 03-04-2008, 04:31 PM   #8
BrettsE30
Your Ride: 1990 325i 2dr.
Same problem
I have a 1990 325i and going through the same thing. Only my light will go out, for a while, and then come back on. Still looking into it but have you found the problem? Please let me know.
Unread 03-04-2008, 07:55 PM   #9
i like pelican parts, and Tischer BMW has a good discount for forum members.
troubleshooting ASC and ABS light falcon900 E36 6 08-08-2007 08:29 PM
e36 abs idiot light bbimw E36 3 08-07-2007 08:16 PM
ABS Light from HELL!!! So it's on again after the dealer fixed it! delmarco E36 7 08-06-2005 10:04 AM
Back to the dealership! yearly inspection, ABS light, new pads&rotors$$$$ delmarco E36 14 07-07-2005 09:42 AM
ABS check light came on!!! please HELP!!!! delmarco E36 9 07-06-2005 08:27 PM
