Unread 11-03-2007, 09:04 PM   #1
bigtom21485
Your Ride: 99 328iC
sticking throttle
my 99 bmw 328i convertible's throttle is sticking. And the day it started, the check engine light came on. However, the car's exhaust is clear and it does not hesitate or lack power. any ideas?
Unread 11-07-2007, 06:32 PM   #2
exodus
Your Ride: '94 325is
I'd clean your throttle body and lube it up, as well as checking the connection to the throttle position sensor and check on the traction control throttle body.
You could also try taking the car to autozone to have the codes read, that should give you a good idea of where the problem lies.
Unread 11-07-2007, 11:06 PM   #3
Is it the actual throttle sticking or the pedal?
Also, if the check engine light is on, it's throwing a code. Try the five stomp method to read it for us.
Unread 11-08-2007, 11:59 AM   #4
compactdisc
compactdisc's Avatar
Your Ride: 93' 325is
CAre to explain this method?
Unread 11-08-2007, 12:03 PM   #5
i thought thats only on OBD1?
Sounds like u have to clean your thortlle body.
Is your car fly by wire or a cable drivin throttle?
Throttle position sensor? Jimmie34 E12, E28, E34, E39, E60 13 08-16-2010 09:48 AM
Torn rubber gaiter to throttle body Chevell E36 5 07-09-2007 12:08 PM
WTB: 6 cylinder throttle body's ///M Power Bmw Cars For Sale/Wanted 0 04-05-2006 02:03 AM
Big Bore Throttle Body xsperf E36 7 04-04-2006 09:06 PM
E36 Throttle Body Bore out ?? defkon99 E36 10 09-18-2005 09:36 AM
