Unread 11-02-2007, 02:12 PM   #1
player2poet
Your Ride: 1985 bmw 325
leak on passenger side window
i got into my 85 325 es the white one and the carpet was soaking wet from all the rain .looked all over for leak discoverd that along the door between the crome strip and door was seeping under the crome strip down into the car .what should i do use some kind of sealent on top or pull the strip and re do the whole thing .worried i might make it worse by pulling it off ?
Unread 11-04-2007, 07:44 PM   #2
Exilion
Exilion's Avatar
Your Ride: 1991 325i
First check all your gaskets because the chrome should not connect to the interior (if you look closely at my sig I dont have most of my chrome). However it is possible there is some leak due to whatever reason. The chrome normally just pops off and the only thing you should worry about is the plastic mounting nuts. As far as sealant I can't really say... I'd assume something similar to what you use on gaskets if nothing else check out your local auto store (I like using advance auto for generic stuff). If I get a chance I'll look something up for ya.
Unread 11-04-2007, 07:49 PM   #3
you can get a new door gasket. Runs for about $100(i got it for that price at the dealer over a year ago...so it may be cheaper.)
also check your sunroof...cause it may be leaking into that area and then leaking down through your headliner?
just an idea?
I know on my e30 the rain came in the drivers side in the top corner of the door, I replaced the gasket and all was good.
Unread 11-04-2007, 08:31 PM   #4
Exilion
Exilion's Avatar
I'd check the condition of the gaskets first. On my car I was able to just simply reglue them because the rubber was still good, and it was just the glue had dissolved over the years. I donno it's always good to check the cheap solutions first, because usually it's not just one gasket.
Unread 11-05-2007, 01:57 PM   #5
player2poet
thanks guys replaced gasket so far so good !!!
Unread 11-05-2007, 03:46 PM   #6
Exilion
Exilion's Avatar
you're welcome
DYI: **BavToys ANGEL EYES Install Guide E46** habbie Lighting DIY's 12 10-12-2012 11:11 PM
How to change your side mirror glass. doughboyea BMW OEM Parts Department DIY's & FAQ's 3 11-07-2010 01:43 PM
oil leak in 94 730i BMW730i 7 Series (E23, E32, E38, E65, E66) 6 08-21-2007 08:28 PM
rear passenger bearing help DAM323I E46 2 05-22-2007 09:15 PM
American Airlines First Class Passenger komodo Comedy Collection
7 05-11-2005 07:00 PM
