Lighting
Sponsored by: BavToys.com
Unread 11-23-2005, 09:13 PM   #1
DDE Cold Start Fix
In the winter times when the temperature hits in the 30's sometimes your DDE will take a good while to get to the good temperature to get on. A fix for that is to hard wire the ballast in...
The ballast is located between the high beams and the low beams, it's a small black box...
GENTLY take it out
Then find the two connectors...
Cut the cables ONE AT A TIME!!!! then hard wire them, and you'r done
Unread 11-23-2005, 09:44 PM   #2
why 1 at a time? just so you know which one goes to which?
Unread 11-23-2005, 10:23 PM   #3
Yeah, you have 4 white wires, if you cut them all at once how the helll will you know where to connect them
Unread 11-23-2005, 10:56 PM   #4
well you could mark em i guess, but thats funny, why would the connectors make the angel eyes go dim?
Unread 11-23-2005, 11:08 PM   #5
the connection isn't great on them, meaning the power/voltage the ballast is creating, not all/enougth of it is flowing to the DDE's to warm them up quickly to get them to be at full potential...
Unread 11-24-2005, 01:31 AM   #6
What do you mean hard wire them? I don't get the last step...
Unread 11-24-2005, 01:35 AM   #7
voca
he means splice the wires together to bypass the connector. just wire em straight up.
sold..
Unread 11-24-2005, 01:37 AM   #8
ibew 595
I really doubt that is the problem. Ballasts tend to not work very well in the cold unless they are designed for that application. If it were the connections then they wouldn't work in summer either or wouldn't work well as they get older. Put a florescent light out in the snow and see how well it starts up.
2000 740i Impala Brown
Unread 11-24-2005, 10:38 AM   #9
You might doubt it, but the people who sell this stuff recommend doing this
Unread 11-24-2005, 01:25 PM   #10
bmw4life
Title: Addicted BMW Freak
Rate My Car: 112 / 340
Has it worked for you?
Unread 11-24-2005, 04:35 PM   #11
so far yes, but I'll only know for a fact when temperature goes down a lot once again, the weather was decent today
Unread 11-24-2005, 07:51 PM   #12
Spieluhr
Title: ///M Driven
he is right, it does help with some of the issues. And those black connectors really are shit. When I was having some issues I shocked myself once. It makes it all so much easier to just splice em togehter, solder, whatever.
Unread 11-25-2005, 10:41 PM   #13
OK, this is a fix! It was 32 when i got to my car tonight heading home from work and the DDE's led right up...
Unread 11-27-2005, 03:34 AM   #14
ibew 595
Glad it worked for you. Kind of sad if you do a mod and it kind of works.
Unread 11-28-2005, 01:37 PM   #15
ANGEL EYES cold start fix by ROOZ komodo Lighting DIY's 1 12-07-2014 04:01 AM
Cold Start and VANOS Knock? Mercenary(FH) E36 11 11-26-2006 06:01 AM
Cold Start Question cacioa E36 3 11-21-2006 11:10 AM
Cold start bug Rooz E46 20 09-12-2006 11:40 AM
DDE Cold Start Fix Rooz BMW OEM Parts Department DIY's & FAQ's 25 05-05-2006 09:22 PM
