Lighting
Sponsored by: BavToys.com
Unread 10-24-2007, 03:06 PM   #1
bmw535i
Your Ride: BMW M5 E39 BMW 635csi 1986 BMW M535i 1986 BMW 530d BMW 540i Touring BMW 730i BMW 325i E30 Cabrio
Lightbulb E39 High Beam Fault
My 1997 e39 535i has a constant power feed to the right hand side high beam bulb. Even with the key out the right hand bulb stays on. Is this controlled by an ECU or relay, and where would i find them.
Unread 10-24-2007, 03:53 PM   #2
Moved to lighting for better exposure
Unread 10-03-2008, 03:01 PM   #3
x150
Your Ride: 2006MY Audi A4 2.0 TDI Avant
Thumbs up E39 High Beam Issue
The problem you have is associated with the Lighting Control Module. On a right hand car the module can be found behind the kick panel on the lower right hand "A" Post. It might be in the same location on a left hand drive car. The High Power Switching FETS have failed and they are located on the PCB inside the lighting module. It will be very expensive to replace the module at approx 250 or US$500. Replacing the FETS is much cheaper and is a specialised job because the FETS are soldered onto the PCB, I have successfully repaired 2 cars with this fault.
Idle vibrations E39 540i lacikam E12, E28, E34, E39, E60 15 10-24-2011 11:47 PM
E39 high beam problem. tracey.mark@tiscali.co.uk E12, E28, E34, E39, E60 4 01-30-2011 11:56 PM
high beam problems HELP!!! junkman123 E21, E30 6 01-07-2011 06:38 PM
E39 no high beam Wendy Lighting 4 07-23-2007 02:34 PM
ZKW high beam question... Umnitza must read... Rooz E36 3 06-25-2005 12:06 AM
