Unread 05-23-2005, 03:15 PM   #1
delmarco
delmarco's Avatar
Rate My Car: 227 / 340
Trouble starting car after sitting cold for 3 days..help!?
So this morning I get into my car and turn the key and the engine starts coughing really loud..but refuses to turn over...I pop the hood, inspected everything and I repeated starting the ignition for about 5 to 6 minutes (about 15 to 20 turns) before the engine actually turned over and started...when it did..the car was reving wildly and the engine was vibrating alot for a few seconds before settiling in to normal behavior.
Conditions: My car has been sitting cold for three days on driveway and we've had lots of rain in NY during this time. Actually last night I went into my car and started it (to reset the alarm memory that had come on somehow) and it started fine. I also noted that there was some water leaking out from my windshield rubber trim above the DME area and the trunk lid.
I've Ruled Out: It is NOT the Air Mass Meter or Air filter since that is newly replaced (July 2004), Ignition switch is new as well, It also shouldn't be electrical. My neighbor who is good with cars said it sounded like a fuel component or line is clogged up.
Suspicions: Altenator, maybe water got into some key component that has to do with starting the engine such as DME, Altenator, Engine block, Maybe my Belts or timing chain needs to be replaced. Maybe fuel lines are clogged up...
HELP?
Unread 05-28-2005, 09:18 AM   #2
delmarco
delmarco's Avatar
thanks, everyone...for being so so so helpful!
bah....
Unread 05-28-2005, 09:26 AM   #3
cruzin 323is
Send a message via AIM to cruzin 323is
the car isn't getting any gas, and spark to get the car started... i'd check the fuel pump... or maybe even spark plug/igniton coil.... not too sure though del, sorry!
24 01-22-2008 05:54 PM
You Might Be a Ricer If.... komodo Comedy Collection
20 11-08-2006 11:06 AM
My car exploded, and other hell from the past two days. (pics) komodo E36 120 02-17-2006 01:31 PM
