Unread 10-12-2007, 12:23 PM   #1
mmw
Your Ride: 1994 325is
Replacement battery
Has anyone used a battery other than the one specifically called for? My son's 94 325is is need of a replacement and the few auto stores that carry the "proper" size unit want $125 or more. I haven't gone in yet to measure the battery and see if others fit, but it's hard to believe that another model for a "normal" car at a more reasonable price wouldn't fit. Just trying to save the kid a few bucks!
Any info is appreciated. Thanks!
Unread 10-12-2007, 01:17 PM   #2
I replaced the original battery on my '95 325i this past winter with an Interstate that cost me about what you were quoted, maybe even more. Yeah, maybe more than what one would expect, but it was the exact fit for the car, Interstate has a good reputation, and I figured if I get twelve years out of this one as well, that's about $10 a year.
Unread 10-14-2007, 09:38 AM   #3
Chronic Bimmer
Your Ride: 1992 325i
I put in a non-stock sized battery in my 92 325 and it fits fine. Put an exide gel cell in it, works great. Cost close to 200 though
Unread 10-14-2007, 11:28 AM   #4
DAMN!!! $125!!! <-- way too much.
In my opinion, you can buy just about any battery (Correct physical size doesn't really matter that much, you'll just have to mess with it more. CCA and CA are really the only specs you need to be worried about.) with a warranty on it and it'll work fine. (As long as you aren't running a giant amp/subs combo.) I went to O'Reilly's and I think I got one about two years ago for $75. I haven't had any problems since.
Unread 10-14-2007, 11:42 AM   #5
^^^Pretty much, but since it's located in the trunk, you have to get one with a vent tube, and make sure it properly vents out of the car.
battery problem V-tecKILLAH E12, E28, E34, E39, E60 3 03-07-2007 05:07 PM
New battery, better running? 3050rpm E36 5 03-03-2007 12:04 AM
battery tip abdallah_n E12, E28, E34, E39, E60 18 02-04-2007 05:55 PM
Check Your Battery Compartment 3050rpm E36 4 09-15-2006 07:06 AM
Mounting Battery newest2002tiiowner 2002 1 08-28-2006 05:54 AM
