Unread 10-06-2007, 04:03 AM   #1
M.C. Sketuls
M.C. Sketuls's Avatar
Rate My Car: 285 / 340
Your Ride: 86 BMW 325E, 01 Audi A4
Send a message via AIM to M.C. Sketuls Send a message via MSN to M.C. Sketuls
No heat. I NEED heat!
So i just replaced my thermostat and thermostat housing. I have hot heater hoses until they go under the intake manifold. Going to the heater core (firewall) the hoses are cold. It's getting to be 30's here in Utah and i need heat. No heat, No dates! I need this fixed STAT! What is under the manifold that takes my heat away? BTW, i have an E30 325E
Unread 10-06-2007, 10:21 AM   #2
stevo
Your Ride: 1997 318se Touring
air lock or blocked heater matrix?
Unread 10-06-2007, 01:13 PM   #3
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
For the pics, upload them on the file manager and then click the insert picture icon.
For the heater part, let me check around and ask some friends. You might have a clogged hose. or like stevo said.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 10-06-2007, 10:30 PM   #4
bleed your radiator, there is air in your system, make sure when you bleed it the heater is on full blast so the coolant can circulate through the heater-core
Unread 10-06-2007, 11:27 PM   #5
M.C. Sketuls
How does one bleed the radiator? Via the screw on top of the thermostat housing?
Unread 10-07-2007, 01:47 AM   #6
elsabor67
elsabor67's Avatar
Yes. once you see water start coming out steadily, then close.
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 10-19-2007, 11:34 AM   #7
jcjdavis1
jcjdavis1's Avatar
Your Ride: 1989 320i tourer
Hi Try this-
Engine running
Heater controls set to hot
Header cap off
Keep squeezing all water pipes watching for air bubbles
Top up coolant as required
When satisfied no air put header cap back on
Release bleed valve on thermostat housing and check that no air and only coolant is coming out .
It worked for me.
Unread 10-19-2007, 12:03 PM   #8
denyo77
denyo77's Avatar
Rate My Car: 198 / 340
Your Ride: 1988 325i Touring
Help me put a picture in my sig!
is the pic already uploaded to a place on the internet? Else, click the "file manager" button (the button next to "wallpapers") and upload it there. Then just type [IMG], paste the URL you got after uploading, and type [/IMG] after the picture. If you still have problems, send me a PM.
Unread 10-22-2007, 01:31 PM   #9
M.C. Sketuls
Ok... so i Put a heat gun to my Hoses going in and out of my firewall. The temp drops ALOT from the time it goes in, 160 somethin, to the time it comes out, 120 somethin. Bad heater core/ heater controle valve?
Unread 10-22-2007, 06:53 PM   #10
beem
Your Ride: '00 540/6 Dinan S2(sold), '90 525i/5, '01 Audi S4
Send a message via AIM to beem
bleed, bleed, bleed, and bleed. seriously. the m20 motors can be a pain
...let's go to the highway!
Member of the Spririted Driver Club.
No heat, no AC, No defrost/defog?? celsdogg E36 1 05-27-2006 07:11 PM
Missing Floor Heat 1995 318i singring E36 2 12-27-2005 05:56 AM
