Unread 09-21-2007, 09:20 PM   #1
zipwax
Your Ride: 1999 M3
Send a message via MSN to zipwax
Passenger Door Lock actuator broken
My M3 convertible (E36) has a bad passenger door lock actuator. It won't lock when I arm the car, and won't unlock when I disarm the car. it won't toggle when I press the little lock button on the car's center console. I don't hear it trying to actuate the lock either. No sound coming from it. I'm looking for advice on where to start looking. I checked the fuses under the hood as a 1st step, and haven't looked or checked elsewhere yet. If it is the actuator (and I heard this is probably what it is), can I get the actuator out of the door w/o having to remove the window? I got myself the Bentley manual, but it doesn't talk about the door lock actuator AT ALL. Weird.
thanks in advance.
Unread 09-24-2007, 05:36 PM   #2
Anyone got any ideas on this one?
Unread 09-24-2007, 09:00 PM   #3
zipwax
Your Ride: 1999 M3
I figured this out and the steps to take. First off, you can check the voltages to the lock actuator w/o taking lock actuator out. Wedge something into the loop hole on the body where the door latches, so you can use the button to lock and unlock the doors even when it's open, and hook up a 5v lightbulb or multimeter to look for the voltage spikes between the heavy-gauge black wire and one of the other heavy wires when you press the lock button. (I used a digital multimeter with a single-run trigger so I could look at the waveform!). but another lock actuator, a functioning one, could be used too. Turns out it was the lock actuator. I eventually succeeded in taking the actuator out without removing the window first (it was near impossible, but still possible).. The actuator looked perfectly fine, but it just didn't work. The new one worked just fine! That's all I know.
Unread 09-26-2007, 09:29 AM   #4
Glad you figured this out. Thanks for posting the solution for others.
Sagging Passenger Door Thea_VC 7 Series (E23, E32, E38, E65, E66) 1 08-28-2007 07:19 PM
passenger window wont go down and ac not cold anymore gabe_beamer E36 3 06-19-2007 03:18 PM
Air Marshal Kills Passenger komodo United Off Topic  **FOR MEMBERS ONLY** 8 12-08-2005 06:40 PM
First Passenger ride Ever BimmerKris E21, E30 18 08-14-2005 06:55 PM
American Airlines First Class Passenger komodo Comedy Collection
7 05-11-2005 07:00 PM
